Saturday!
Went to work in the am but had all afternoon set aside to piece the trailer together. Ran over to my friend Sean's to borrow his angle grinder.
It took me a while to figure out how to attach the axle bracket. Mainly because I wasnt sure where to locate the axle. I read some threads and I've also talked to another cubbie builder about where he located his axle.
Finally I just punted and used the existing holes on the frame. The plans call for the axle to be 36 inch from the back. Mine will be about 42 inches from end. But I'm not building out the galley as elaborately as the standard plans call for. Fingers crossed.
You can also see the wooden cross piece I prepared. I painted it black because I wanted to seal it where I doubted I'd get the asphalt emulsion. I happened to have some black.
