Rimple Build in Texas
Postby Doc Milo » Wed Feb 15, 2012 12:27 pm
Well I'm taking the plunge and embarking on my first build. I have been lurking for a while, picking up some information and inspiration for all the other builds on this board. I have settled on Andrew's Rimple design. I had initially wanted to build a true teardrop, but the Rimple has sort of grown on me. I'm going to make it 54" wide on the inside to accomodate a full-size mattress, built on a HF trailer. This will be a pretty plain build, no running water or satellite TV, just something to get me up off the ground when camping/hunting. I still have some planning to do and decisions to make (I've been putting off the electrical part just due to the intimidation factor), but I have enough to get started I think.
Bought the 3/4" plywood for the walls and cut out the profile last night. Color scheme will probably change like 5 more times before I actually have to paint but here's what I'm thinking so far. Any suggestions for modifications are welcome and appreciated!!
Doc Milo
Images: 18
Re: Rimple Build in Texas
Postby Bob Patterson » Wed Feb 15, 2012 12:44 pm
Welcome to TNTTT, Doc. You've found a great place to hang around. It can get very addictive. I like the design you have chosen and look forward to your build. :applause:
All the best,
Bob (& Reggie)
____________________
The Tintanic Build Thread
Bob Patterson
Images: 210
Postby IndyTom » Wed Feb 15, 2012 2:14 pm
Great looking design. Looking forward to seeing pics of your build.
Never trust a skinny cook
IndyTom
Images: 34
Postby starleen2 » Wed Feb 15, 2012 4:25 pm
from a fellow Texan - what part of the state are ya' in?
starleen2
5th Teardrop Club
Images: 44
Postby Doc Milo » Wed Feb 15, 2012 8:26 pm
I'm up in the Panhandle - close to Amarillo. Plenty of good camping around, within a pretty short drive, anyways...
Doc Milo
Images: 18
Postby Doc Milo » Wed Feb 22, 2012 9:12 am
Got the walls 'cut out' night before last. I weighed the wood I removed and it came to just under 60 lbs, so it was a pretty good diet. I went by Harbor Freight yesterday and picked up the 1720# trailer ($280 with coupon) and will try to get that painted and put together within the next week or so, hopefully. At that point I can take some measurements and firm up some design questions I've sort of been on hold about. Still a little bit in the planning phase on floor and floor/wall attaching. More to come!
Doc Milo
Images: 18
Postby Doc Milo » Wed Feb 22, 2012 11:31 pm
I have no earthly idea why these are upside-down; they are right-side up in the gallery. I'll try to fix tomorrow.... :goodnight:
Doc Milo
Images: 18
Postby Doc Milo » Sun Feb 26, 2012 8:28 pm
Got the Harbor Freight trailer put together this weekend, went together (mostly) without trouble. I scooted the axle back to 38.5" from the rear, which seems to be pretty close to a consensus around here. I figure I can shift weight later on if need be. I also made a couple of design decisions in the process. I decided to keep the red colored trailer - I wasn't crazy about it at first but I think it'll look ok in the end. My wife assures me we can make the color scheme work. Also decided to stick with an overall width of 48 instead of the 54" as originally planned (the KISS principle applies here).
Garden variety HF trailer....
88287
I had to see how it was going to look.
88286
88285
Doc Milo
Images: 18
Postby Corwin C » Fri Mar 02, 2012 11:25 am
One reason why most choose to paint the HF trailer is because it fades to PINK ... and not a very pretty pink at that.
Something to think about...
Welcome to the forum.
Corwin
Image Image Image
"Government is like a baby. An alimentary canal with a big appetite at one end and no sense of responsibility at the other." -Ronald Reagan
Not Racist, Not Violent, No Longer Silent - - - FAITH - HOPE - CHARITY
Corwin C
Images: 44
Postby aggie79 » Fri Mar 02, 2012 2:11 pm
Welcome to the forum Doc! It's good to have another Texas teardropper on board! Take a spin by the South Central section if you haven't already to see events in our area.
Corwin C wrote:One reason why most choose to paint the HF trailer is because it fades to PINK ... and not a very pretty pink at that.
While I used a custom frame on my teardrop, I have a HF utility trailer. It's been a good hardworking trailer for me, but I have to agree with Corwin. The paint does fade to pink pretty quickly.
Take care,
For more on our Silver Beatle teardrop:
Images: 604
Back in black
Postby Doc Milo » Sat Mar 17, 2012 5:27 pm
Thanks Corwin, Tom. You talked me into painting it and saved me from the humiliation of showing up at the deer lease with a pink trailer. It looks much better flat black, anyways. I've discovered that changing colors in real life is harder than it is in sketchup, though....
Doc Milo
Images: 18
Postby CliffinGA » Sun Mar 18, 2012 1:08 pm
Welcome Doc to the forum and the madness I lived up in your neck of the woods for qute awhile and even went to Tascosa High in Amarillo. Looks like your trucking along and its looking great. Keep at it,
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby PanelDeland » Sun Mar 18, 2012 4:11 pm
Doc,looks like a great design.There's more Sq ft of interior room in the Rimple that just about any other design.
Gosh Cliff,Trashcosa is the only High School in Amarillo that I didn't attend.
"I know the voices in my head aren't real,but they have some really good Ideas!"
PanelDeland
Postby Doc Milo » Sun Aug 05, 2012 5:49 pm
After an extended hiatus, here is a bit of an update on the build so far. I've been idle, yes, but not completely idle.
I made the bottom of 7/16" (top) and 1/4" (bottom) plywood, with 1/2" framing and insulation between them.
96417
I coated the bottom with 2 half strength, then 2 full-strength coats of spar urethane, over which I applied 2 coats of Ultra-roof 1000 elastomeric roof coating (this is instead of the roofing tar). The picture doesn't show it well but this stuff was brighter than the sun - I actually had to wear sunglasses when I put it on.
96418
96419
When I went to attach the floor to the trailer, I saw that there would be a tiny gap (1/8" or so) between the frame and the floor due to the fact that the cross members sit a little bit lower than the side rails. After some suggestions from some helpful folks in the tips & techniques forum, I screwed some aluminum spacers down in the middle to provide support.
96416
The sides are 1/8 - 3/4 - 3/16 plywood, with insulation installed in the cutouts on the middle piece.
9642196420
I'm going to try to stay busy on it to have it ready in time for Fall/Winter 2013...
Doc Milo
Images: 18
Users browsing this forum: coostv, les45 and 3 guests
