FL 5x9.5 Side walls mocked up 8/18/12 pg.2
Postby GRY GHST » Sun Jul 29, 2012 2:25 pm
Well I've been searching the web for a few weeks and now I'm starting my first build.
Got my HF 4x8 w/ 20% off last night then ran to HD this morning for some wood.
also found a computer desk in the dumpster by the house and grabbed the slide out off of it.
The trailer is just about together, then I can start the floor.
taking some cues from Zack's XII build
John
my 5x9.5 build viewtopic.php?f=50&t=51618
GRY GHST
Re: FL 5x9 on HF build
Postby pjo129 » Sun Jul 29, 2012 7:41 pm
Nice start. How do you plan on using the computer shelf?
Pete Olson
Newburgh, IN
pjo129
Images: 73
Postby GRY GHST » Sun Jul 29, 2012 7:59 pm
@pjo129 - the computer shelf will be a pull out for either a cooler or stove.
John
GRY GHST
Postby Forrest747 » Mon Jul 30, 2012 11:16 am
JMO
I can not see the slide out being able to support a stove or cooler on its own. I there was times with my old computer desk that it barely held a keyboard or hands at the same time. be careful. pics would help of it
Forrest747
Cowbell Donating Member
Images: 447
started the framing
Postby GRY GHST » Mon Jul 30, 2012 6:06 pm
@ Forrest - I will have support for under it if I use it. I'm thinking mainly just to slide it out from under a counter.
I put the fenders on and got some work done on the sleeping area floor framing today.
the 2x4s are lag bolted to the steel frame. the 1x2s were dadoed in and will be glued and screwed
the battery/batteries will go under the floor in front of the axle.
there will be storage under floor in the section in front of that.
I also plan on making a ramp the stores under the frame to slide out so my dog can get in and out with ease.
John
GRY GHST
Postby GRY GHST » Tue Jul 31, 2012 7:53 pm
didn't get much done today. picked up some 1x8x8s for the frame sides. mocked up the battery placement and tongue
battery compartment will hang 5" below the frame, this should leave plenty of clearance.
also picked up a new cooler from target
John
GRY GHST
Postby GRY GHST » Wed Aug 01, 2012 9:01 pm
got a few pieces of wood cut today (no new pictures) did not have much time to work on it.
*been pondering the need to move my axle back or leave it stock.
took some measurements the bed base 60x80 will start 7.25" forward of the steel frame and end 19" behind the axle (stock placement). I plan on running a 5000btu window ac in the rear and the batteries will be in front of the axle. any feedback would be appreciated.
if I work a long day tomorrow I'll have friday off and should be able to complete the base ::fingers crossed::
John
GRY GHST
Postby GRY GHST » Thu Aug 02, 2012 7:17 pm
got the sleeping deck cut to size after work today 60"x80" I just need to join the two pieces now
I've decided to cut down the 2x4s (now that I got my table saw out) to drop the deck to just on top of the fenders.
I will will have the majority of the day tomorrow to work on the tear so I should make some progress.
John
GRY GHST
Postby absolutsnwbrdr » Fri Aug 03, 2012 8:55 am
Nice work John. I like the dadoed 1x2s. I definitely went overkill with more 2x4's there. :lol:
I did notice one thing in that last picture.... it looks like you're missing the bottom plate at the end of the tongue and some bolts :o
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby GRY GHST » Fri Aug 03, 2012 1:59 pm
absolutsnwbrdr wrote:Nice work John. I like the dadoed 1x2s. I definitely went overkill with more 2x4's there. :lol:
Thanks Zach, did you ever get the total weight on the XII
(the tongue is just mocked up it's not completed.)
John
GRY GHST
Postby absolutsnwbrdr » Fri Aug 03, 2012 2:02 pm
GRY GHST wrote:Thanks Zach, did you ever get the total weight on the XII
Yeah... its a little hefty, not too bad though. My Subaru still moves pretty well with it. 1100lbs, with a group 27 battery.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby GRY GHST » Fri Aug 03, 2012 8:28 pm
absolutsnwbrdr wrote: Yeah... its a little hefty, not too bad though. My Subaru still moves pretty well with it. 1100lbs, with a group 27 battery.
not bad at all my V50 is rated for up to 2000lbs with a 200lb tongue weight, but I'm still shooting for as light as possible with a quick build.
The hitch for the Volvo came in yesterday, I'll likely get it mounted at some point this weekend. I still need to get a wiring harness though.
I did not get much accomplished today. I did get the 2x4s cut down to the height of the fenders. I also got the tongue crossmember bolted up.
I'm also leaning toward mounting the AC in a tongue box and hacking it to vent up into the cabin (per Shadow Catcher's thread)
the cardboard represents the outline of the stock LG 5000btu unit from Home Depot $99
John
GRY GHST
Postby GRY GHST » Sat Aug 04, 2012 10:36 am
re-dadoed the 2x4s since I ripped them down last night to drop the deck
then joined the two deck sections together with biscuits and gorilla glue
not sure what to do now since the glue needs to cure, maybe install the hitch on the V50
John
GRY GHST
installed trailer hitch on V50
Postby GRY GHST » Sat Aug 04, 2012 1:37 pm
cut out two panels for the sub floor front and rear storage compartments
also got the hitch on the V50
John
GRY GHST
Postby GRY GHST » Sat Aug 04, 2012 6:22 pm
pick up a 26"x32" emergency exit window off craigslist. it looks like it was meant to be mounted horizontally, I was hoping to mount it vertically does anyone know if this would cause any issues (IE: leaking)?
I also ran to Northern tool and picked up a tongue jack on sale $17.99
John
GRY GHST
Users browsing this forum: No registered users and 30 guests
