First build. 4'x8' HF Teardrop (Lots of photos)
Postby Swank1975 » Mon Mar 10, 2014 6:09 pm
The wife and I pulled the trigger Sunday and started on our build.
Using a 4'x8' HF Super Duty trailer. Trailer is assembled and wheel bearings were cleaned and packed upon assembly.
Swank1975
Re: First build. 4'x8' HF Teardrop
Postby bc toys » Mon Mar 10, 2014 8:42 pm
looking good keep pics and updates coming our way
bc toys
Images: 42
Postby Kullas » Mon Mar 10, 2014 9:08 pm
So far so good. looking forward to seeing more
Chris
Kullas
Postby Nate.petty » Wed Mar 12, 2014 8:46 am
Looking forward to seeing you build.
Nate.petty
Postby Swank1975 » Thu Mar 13, 2014 9:24 pm
Floor went on today. 3/4" treated ply coated on the bottom with a waterproof membrane you brush on joints for shower pan installs i had left over from the bathroom project. The stuff goes on blue and dries green. It is a rubber coating. I figure it will help keep this floor protected from spray. I used carriage bolts and bolted throught he plywood and the top holes on the HF trailer. I used nylon locking nuts. Next is to lay out the side profiles for the walls.
Swank1975
Postby Swank1975 » Fri Mar 14, 2014 6:48 pm
Started on the side profile today.
Have to splice the tail end of the wall to get the length I want on the 8' trailer.
Once this glue dries I will finish the profile at the rear and cut with jigsaw. Then I will use this side as a template for the other side and cut and extend it.
Swank1975
Postby Kullas » Fri Mar 14, 2014 10:32 pm
looking good
Chris
Kullas
Postby Swank1975 » Fri Mar 14, 2014 11:15 pm
Teaser of profile.
Swank1975
Postby Swank1975 » Sat Mar 15, 2014 7:37 pm
Today's update. I still need to go get my metal 90degree brackets to secure the walls down to the floor. Where the carriage bolts were on the floor I measured their spots out where the wall would sit on them and routered those spots out. The spars are 2by lumber being ripped down on the table saw then glued and nailed in place with the nail gun. I want to get the walls secured, the spars in, and the inside headliner in place. Then I'll start on the wiring for lights.
Swank1975
Postby Swank1975 » Sat Mar 15, 2014 11:22 pm
More pics of tonights progress.. I secured the walls down to the floor with metal bracket from home depot with holes in it. I cut a 4' piece into 12 - 4" long pieces and used screws to secure them tot he walls and floor. My walls sit on the 4' wide plywood so the inside dimension is 46 1/2". I figured this will make covering the roof with 4' wide aluminum later much easier.
Swank1975
Postby Swank1975 » Sun Mar 16, 2014 2:26 pm
Today I am finishing up the spars, roughing in the roof vent, and starting the hatch. After I finish those items it's off to get luan and sanded ply for the interior and galley work.
Swank1975
Re: First build. 4'x8' HF Teardrop (Lots of photos)
Postby Swank1975 » Sun Mar 16, 2014 3:34 pm
And more photos. This is a blast. So I built the galley hatch and cut it out.
Swank1975
Postby Woodpecker » Sun Mar 16, 2014 6:05 pm
Huzzah! I love the smell of sawdust. Looking nice and strong! :applause:
Woodpecker
Images: 186
Postby Swank1975 » Sun Mar 16, 2014 6:37 pm
Thanks Mnkeeboy.
Swank1975
Postby jbyrd » Sun Mar 16, 2014 8:14 pm
Looking really good!!!!
Til later, See ya
Jeremy
My build journal #1 "SOLD" : viewtopic.php?t=45945
my build journal #2 "SOLD": viewtopic.php?f=50&t=59216
jbyrd
Images: 172
Users browsing this forum: Google [Bot] and 6 guests
