Sleepin Around, New Zealand. The Build
Re: Sleepin Around, New Zealand. The Build
Postby KCStudly » Sat Jun 02, 2018 12:55 pm
Nice.
Did you do anything special to make sure the brake backing brackets were all squared up and in the right place? Many people find this to be daunting, and you made it look easy. Perhaps others could benefit from a bit more detail about this stage, or was it just as easy as it seems?
Any concern about heat from welding getting to the rubber "spring" bond? The trailing arms look beefy enough to dissipate the heat, but wrapping the axle housing in this area with a wet towel would easily provide added insurance.
Images: 8119
Postby Sheddie » Mon Jun 04, 2018 5:16 am
KCStudly wrote:Nice.
Hi KC,
it was a fairly straight forward job. As with anything like this, don't rush it. :thinking: think about it thoroughly :thinking: look at all the options :roll: :thinking: think again.
I assembled all the components on to the stub axle so that I could accurately measure where the mount for the backing plate would be positioned.
The hole in the middle of the mounting bracket was a little larger than I had hoped it might be, so I made some shims to hold it in place while I tack welded it. Once I was happy that all was in the right place and squared up I removed the shims and fully welded it. The heat transfer wasn't a problem, but as you say a wet towel will help there.
Sheddie
Images: 1129
Users browsing this forum: bdosborn and 10 guests
