The Astroliner
Re: New Build... The Astroliner
Postby Vedette » Sun Oct 12, 2014 12:22 pm
I was attracted to your build by the name! :thinking:
Very impressed by what I have seen so far! :thumbsup:
I can appreciate your skill level and am amazed by the wood work done by builders on this Forum.
Having no woodworking skills myself, my builds are much different. :roll: As a street rod builder by trade, my builds are "all" steel.
Do have a board with three holes in it as a wine rack in Miss Piggy though. :R
Keep up the Great Work!
I look forward to following your progress.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Atomic77 » Sun Oct 12, 2014 3:00 pm
Thanks for the kudos! Honestly I'm not much of a woodworker. Welding the frame, paintwork and carbon fiber work is much more my area. I too am impressed from the skill set of the wood Craftsman on here. But I'm learning as I go!
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Postby Atomic77 » Sun Oct 19, 2014 2:32 pm
I made a little progress this weekend finishing up the foam insulation. I'm to a point where I'm going to need some extra hands. I didn't cut the wheel openings when I built the walls so now I'm at a point where I'm ready to stand them up on the frame and figure out exactly where they go. I may be at a stand still until I can get some help! :thinking:
125490125491
Michael
The Astroliner
Atomic77
Images: 309
Postby KCStudly » Sun Oct 19, 2014 6:21 pm
If you can lift them and move them by yourself, you should be able to place temporary cleats, blocks and/or angle brackets/knees that would allow you to place and temporarily hold/clamp until you can get some screws started. In fact, these techniques are highly recommended even if you have help; it is a lot easier to pre-measure and locate smaller blocks, which in turn make it much easier to hold the awkward wall in the correct position when it comes time to mount. It worked for me. :thumbsup:
Images: 8119
Postby working on it » Sun Oct 19, 2014 8:13 pm
KCStudly wrote:If you can lift them and move them by yourself, you should be able to place temporary cleats, blocks and/or angle brackets/knees that would allow you to place and temporarily hold/clamp until you can get some screws started. In fact, these techniques are highly recommended even if you have help; it is a lot easier to pre-measure and locate smaller blocks, which in turn make it much easier to hold the awkward wall in the correct position when it comes time to mount. It worked for me. :thumbsup:
I installed my front wall first...it was the smallest, yet most firmly-mountable piece of the superstructure, so it was the logical first upright to go on. Then, after the glue had set, I verified its squareness, and I used that piece to square up the rear bulkhead while the glue on it. I used long furring strips to maintain their "set". However, they sat that way for over a week, and the furring strips warped, and twisted the rear bulkhead position out of square. Had to correct by using ratchet straps and staples when the sidewalls were being attached. Lesson learned: make sure your braces are strong enough to do their job!
869458694486949
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2220 lbs
156215157958148599
working on it
Images: 455
Postby Atomic77 » Mon Oct 20, 2014 7:58 am
I plan on using similar techniques but they are still too large without help. They aren't so heavy as they are awkward. They are 7' tall and 14' long. Just awkward for one person to handle.
Michael
The Astroliner
Atomic77
Images: 309
Postby KCStudly » Mon Oct 20, 2014 10:10 am
I gotcha now. Didn't realize how big they were. :FNP
Images: 8119
Postby Atomic77 » Mon Oct 20, 2014 1:48 pm
KC I didn't plan on one this big. But my girlfriend got involved and here we are! I do think the size will be nice though.
Michael
The Astroliner
Atomic77
Images: 309
Postby dales133 » Mon Oct 20, 2014 2:30 pm
great build Micheal, my mother just sent me a book of restored retro caravans from new zealand and your design would fit right in.
my design will be quite different but id love to make a retro standy one day.
keep up the good work.
dales133
Postby Atomic77 » Mon Oct 20, 2014 2:46 pm
dales133 wrote:great build Micheal, my mother just sent me a book of restored retro caravans from new zealand and your design would fit right in.
Now that's a book I would love to read! Thank you for your comments. Sometimes it feels like I've bitten off more than I can chew... so it's really nice to have fellow forum friends to cheer us on!
Michael
The Astroliner
Atomic77
Images: 309
Postby dales133 » Mon Oct 20, 2014 3:06 pm
i hear you on the bitten off more than you can chew thing, down here in aussie parts are different or hard to find and trying to do a quality build on a reasonable budgets hart when its $700 a door!
dales133
Postby Atomic77 » Mon Oct 20, 2014 3:22 pm
dales133 wrote:i hear you on the bitten off more than you can chew thing, down here in aussie parts are different or hard to find and trying to do a quality build on a reasonable budgets hart when its $700 a door!
Yes, I understand. Budget is the thing that holds up my project more often than not. :NC
Michael
The Astroliner
Atomic77
Images: 309
It's the little things I guess...
Postby Atomic77 » Sat Oct 25, 2014 5:54 pm
Well I haven't accomplished much lately I guess. But I was able to get some help today. It took three of us to get the walls up and hold them there to make a few marks and take a couple measurements. It was fun to see the walls up and get a feel for the size of the cabin! We're hoping to get Filon sometime around the first of next month. I'm really looking forward to vacuum bonding the walls.
125755125756125757
Michael
The Astroliner
Atomic77
Images: 309
Postby dales133 » Sat Oct 25, 2014 5:59 pm
I like that profile.how does the vacuum bonding work?
dales133
Postby Atomic77 » Sat Oct 25, 2014 6:15 pm
Thank you. Basically we will make a giant plastic bag to put the walls in. We will coat the wood exterior in epoxy then lay down the Filon. Seal up the bag, add a vacuum pump to suck out all the air which forms a vacuum clamp until the epoxy kicks. Kind of oversimplified but that's the jest of it anyway.
Michael
The Astroliner
Atomic77
Images: 309
