Just a brief update. Have not had a lot of time, or the ambition to work on the teardrop lately. I have been trying to get 1-2hrs a day in. The temps are tolerable in the garage. Worst it's been so far is in the 40's. So a sweatshirt and jacket have done the trick.
Still drilling holes, running wires and soldering connections. I've been working from front to back. Hooking up 110v and 12v circuits along the way. I just finished wiring the vent fan. Installed the aftermarket fan speed and reverser controller too. I tested it all out and I'm real glad I upgraded the vent fan. It does a real nice job pulling or pushing air through the camper.
Thought I would post a pic of the first test of the FLW lamps in the headboard. I just cut a chunk of a canvas drop cloth that is for the PMF exterior use. I stuffed it behind the FLW lattice and tried it out. It makes for great lighting in the camper for 90% of the time. However I did not find it bright enough to read by. So I ordered up 2 aircraft style ceiling mount swivel spot reading lights to install overhead on each side of bed.
The picture does not do these lamps justice. The effect is not at all harsh light like it seems. The dimmer works great as well. You can really adjust the light for a nice feel to the cabin. I'm happy with the results.
You can see the hole in the back of one cubby hole under the lamp. That's for the 12v usb/lighter style outlets for that side of the bed. There is one on the other side in same location as well. So I am at about the half way point of completing my wiring. I intend to keep chipping away at it while the weather holds up.
- flwlightsa.jpg (86.25 KiB) Viewed 3231 times
