The axle will take 3 weeks for delivery. That's plenty of time to get a start on the walls and floor.
Andrew Herrick wrote:I'm excited to watch your build play out. Designing an off-road teardrop is a fine dance between weight, strength and cost.
I'm curious to know what coupler you're using. When you say "off-road" teardrop, do you mean a rock crawler? I've only ever used ball hitches, but lots of the builds over at Expedition Portal use pintle hitches or articulating couplers like the Lock n' Roll.
Oh, and one solution to a wet mattress is a tatami mat, Froli spring mat, Hypervent or any number of similar products. They allow ventilation under the mattress, and they seem to be big amongst boaters in the Pacific Northwest.
kokomoto wrote:I ordered the Dexter 3,500 lb axle yesterday. Delivery should be in 2-4 weeks. Yesterday was spent cutting the template for the walls from luan. After visiting the local wood supplier, I'm considering building the wall frame from standard 1" boards for an actual 3/4" thickness. It will mean slightly less insulation than the 1" true thickness, but it's easier to come by when shopping for off-the-shelf material. Went shopping for expanded polystyrene insulation at Lowes. The selection was slim. Have to find another source. Too bad there's no Menards in this part of the country.
kokomoto wrote:Andrew Herrick wrote:I'm excited to watch your build play out. Designing an off-road teardrop is a fine dance between weight, strength and cost.
I'm leaning toward the max coupler based on the reviews I've read. Willing to be educated though.
