another first time teardrop builder (update 4/10/18)
Postby Jeremy757 » Sun Nov 05, 2017 3:10 pm
Hello everyone! I saw a teardrop trailer for the first time this past summer on a road trip across country. I knew I had to have one so I have been doing some research over the past few weeks and I have begun my build. I have a few sketches but no real plans I'm just taking it one step at a time. I'm a welder and an electrician so the wood work will be new stuff for me.
I started with making my own trailer. I went with a 5x8 size made out of 2x2x1/4 angle and the tongue out of 3x3x1/4 tubing
while I wait on the axle and suspension to get here my gf and I coated the subfloor with asphalt.
I plan on finishing the trailer portion (with the exception of wheels) this week. once I have the trailer together I will start building the camper portion.
I'm basically just figuring it out as I go along with the help of the internet.
Jeremy757
Re: another first time teardrop builder
Postby Jeremy757 » Sun Nov 05, 2017 4:02 pm
bottom layer of the subfloor in. Image
Jeremy757
Postby pchast » Sun Nov 05, 2017 9:24 pm
That's a good start!
Welcome..... :D
pchast
Images: 97
Postby jsnbergman » Tue Nov 07, 2017 11:51 am
You def got the right tow vehicle! Good luck on the build, and keep us posted.
jsnbergman
Images: 16
Postby Jeremy757 » Wed Nov 08, 2017 7:06 pm
the company I ordered my axle from forgot to ship the leaf springs with it so its holding me up from finishing the trailer half of the build.
I got a cheap set of trailer wheels until I figure out what kind of tires I'm running.
what kind of tires you guys using? I will be driving cross country and would like to travel at posted highway speed. I got 15" wheels and I upgraded the bearings in the hubs to try help with the highway.
Jeremy757
Postby tony.latham » Wed Nov 08, 2017 7:28 pm
6 ply LT radials.
Radials, as we all know, ride better than bias tires. If you were building a double-axle bemouth, I'd absolutely suggest the appropriate bias trailer tires.
Postby Jeremy757 » Sun Nov 12, 2017 6:06 pm
I got my axle and springs installed.
I painted all the raw metal black
installed and bolted down the subfloor
next I'm going to insulate the floor then cover it in half inch ply wood.
I'm going to try and Make a template for my side walls this week. the entire build will be based off the generic Benroy design.
Jeremy757
Postby Jeremy757 » Tue Nov 14, 2017 8:40 pm
I went shopping today :D
I got the floor insulated
covered in 1/2 plywood
as she currently sits
tomorrow I will make my template for the side walls.
Jeremy757
Re: another first time teardrop builder (updated 11/14/17)
Postby Jeremy757 » Wed Nov 15, 2017 10:11 am
I got a new router and I have never used one before. What different kind of bits will I need? Do I need a special router bit to cut the aluminum skin?
Also advice on attaching walls to trailer would be great.
I plan on sitting the walls on top of the lip of the angle iron
Then drilling and counter sinking screws through the wall into the side of my subfloor.
“Glued and screwed”
Then i was going to setup some temporary spars to hold the 2 sides together.
I’m using 3/4” birch for the walls.
I’m a complete newbie at wood working so I’m open to all advice.
Jeremy757
Postby Vedette » Wed Nov 15, 2017 10:41 am
You look like you are having fun with this build already.
Tires! Definitely radials, but don't go too wide.
The only thing you might regret if planning to tow cross country, is that you did not go to a "Dexter" Rubber Ride axle.
They do not give you the bounce that let sprung axles do.
Good Luck with the rest of your build, and we hope to meet up with you somewhere down the road.
Good Roads
Brian & Sandi
PS
If you ever plan to explore the PNW, please give us a call.
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby jsnbergman » Wed Nov 15, 2017 3:48 pm
Jeremy757 wrote:I got a new router and I have never used one before. What different kind of bits will I need? Do I need a special router bit to cut the aluminum skin?
“Glued and screwed”
I set my walls on the floor inside of my angle iron. Your floor might be too thick it looks like to do this. I put a 2x2 inside and screwed from the outside and bottom through trailer and floor/wall into the 2x2. I'm running 3/4 bb walls too but i think my floor is thinner
jsnbergman
Images: 16
Postby Jeremy757 » Wed Nov 15, 2017 6:31 pm
I got the template drawn up last night
cut out the template this evening
cut out the walls
I clamped both walls together then sanded them down with a grinder and flapper disk.
I stood up the walls temporarily to get a visual.
its coming together
Jeremy757
Postby Jeremy757 » Wed Nov 15, 2017 9:05 pm
after sharing some pics on reddit I was informed that putting the door on the passenger side is a smarter choice. so I swapped out the walls to relocate door. Image
Jeremy757
Postby razorback » Fri Nov 17, 2017 3:53 pm
Looks like your having a great time... In my humble opinion, I think you will later regret not having two doors. Just food for thought.
keep the pics coming.
razorback
Postby clamlamp » Fri Nov 17, 2017 7:33 pm
Following
Sent from my ONEPLUS A3000 using Tapatalk
clamlamp
