Building in the Desert on a Trailer with No Name...
Postby kevindford » Tue Jan 16, 2018 3:30 pm
My no-name trailer build has begun, with the assembly of the Northern Tool 5x8 aluminum non-folding trailer.
The deck is going to 5/8" plywood directly on trailer beams, no frame.
The walls and galley bulkhead are insulation panels with 1/4" doug fir ACX to create a type of structural insulation panel (I know they aren't true SIPs, but I don't know what else to call them. Non-structural insulation panels. Yeah, NSIPs.) A local buddy has a 5'x10' vacuum bagging setup and is helping me. I joined the local SynShop to gain access to their carpentry tools, including a 4x8 CNC router.
I've done some design using onshape (free in-browser CAD software), you can look at the panels I made here:
https://cad.onshape.com/documents/6ec1f ... ac616a5dfc
The construction method will be slot and tab, with 1" tabs screwed to the deck with a corresponding slot in the NSIP to fit over, glued and screwed. The galley walls and counter will connect to each other and to the walls the same way.
I think that will be the most interesting part of this build. Lots of new skills for me to learn including: CAD software, CNC router, vacuum bagging, electrical system design.
I'm homeless (by choice) but also couch surf w friends and family when I'm not out exploring the southwest US. Thanks for the ongoing help and sharing of experience to everyone here.
kevindford
Location: Las Vegas, NV & All parts southwest and intermountain west
Re: Building in the Desert on a Trailer with No Name...
Postby tony.latham » Tue Jan 16, 2018 8:06 pm
Sounds like you're headed down an innovative creek. :thumbsup:
I'm a big fan of 1/4' subfloor plywood. It's usually a few bucks cheaper and higher quality than ACX. No voids and a prettier grain.
That floor is fir and the wall is the subfloor plywood. Six bits says your local lumberyard has it –– and no, Home Depot doesn't qualify as a lumberyard.
Postby kevindford » Tue Jan 16, 2018 10:45 pm
tony.latham wrote:Sounds like you're headed down an innovative creek. :thumbsup:
Yeah, that wall is gorgeous. What kind of wood? 'A' side of ACX doesn't have patches either, though.
kevindford
Postby tony.latham » Wed Jan 17, 2018 11:30 am
That's the 1/4" subfloor. I think it's some kind of birch. I believe that subfloor––which is rated for moist environments has to have fewer footballs or perhaps none.
Here's the other side:
The last time I bought 1/4" ply, the ACX was $24 and this subfloor was $22. :D :thumbsup:
Postby kevindford » Mon Jan 29, 2018 9:20 am
3/4" ply for the deck, finished w a couple coats of polyurethane on top and rubberized rustoleum on the bottom.
kevindford
Postby kevindford » Mon Jan 29, 2018 9:25 am
Northern Tool 5x8 aluminum trailer assembly
kevindford
Postby kevindford » Mon Jan 29, 2018 9:28 am
First vacuum bag process for bulkhead panels-
kevindford
Postby Kaz » Sun Feb 11, 2018 8:16 pm
In the desert you can't remember your name:
Kaz
Kaz
Images: 122
Postby kinto » Tue Feb 13, 2018 6:42 pm
Maybe it's just the angle of the pictures, but the door looks almost centered(?)
I'm assuming you've checked that the door & fender will clear each other? :thinking:
kent
Is a hippopotamus just a really cool opotamus?
imay ildbay urnaljay
kinto
Images: 465
Postby tony.latham » Tue Feb 13, 2018 9:31 pm
kinto wrote:Maybe it's just the angle of the pictures, but the door looks almost centered(?)
kent
I think you may be talking about my #3 build since the above photos were taken of her when she was being built in 2015.
Here's a photo of my #1 that has the same profile showing the fender clearance.
It may look farther back than most teardrops. These cabins are ten-feet long with slider storage up front that forms a headboard. Thus the doors are placed right at the hips. :thumbsup:
Postby kevindford » Thu Feb 15, 2018 11:17 am
Kaz wrote:In the desert you can't remember your name:
Cuz there ain't no one for to give you no name :-)
kevindford
Postby kevindford » Fri May 11, 2018 11:19 pm
kevindford
