So we have 2 icy winter storms battling over the uk.
10 ft snow drifts, with the general winter chaos, as people get that, snow and summer tyres are not a good combination.
Break out the captain scotts expedition tea.
A tot of rum for the workers, a waggy finger for the shirkers.
Normal play will be resumed next week.
- sarahs tear assembles.jpg (16.59 KiB) Viewed 1584 times
- sarahs tear exploded.jpg (143.73 KiB) Viewed 1584 times
All the time was mostly spent in planning and ordering.
First was the H13212TAE (Encore 30) Lloyds GP Resin 25kg a general purpose resin is used by professionals who require a top quality, pre-accelerated, thixotropic, orthophthalic resin suitable for a wide range of applications LLOYD’s Register of Shipping approved.
Manufactured by one of the worlds leading producers of resins, it is formulated to provide high quality mouldings whilst keeping styrene emissions low, allowing a better working environment.
Comes in a range of colours I ordered clear, I can add all sorts to it was contemplating a silver mica I will have to play with that.
Then the wood.
The Nose
1x Bendy Flexible Plywood Cross Grain 5mm x 1220 x 2440mm, Bendy plywood is constructed from several veneers all running the same direction which allows excellent flexibility either across or along the grain.
Often used where a curve surface is required.
The Floor
2 x 5mm x 1220 x 2440mm marine plywood
manufactured to BS1088: 2003 standard.
Marine plywood has no surface defects and is fully structural it is also designed to be used in high humidity, damp areas.
will be sandwiching a 75mm sheet of insulation between two boards.
The Walls
2 x 5mm x 1220 x 2440mm Softwood Plywood
EN636-2 & BS5268 (E1) graded ply can be used internally and externally.
A Structural plywood stable and workable making it the ideal choice for numerous building applications.
The Galley and Hatch
3 x 5mm x 1220 x 1830mm Softwood Plywood
EN636-2 & BS5268 (E1) same as above just smaller.
I have lots and lots of 25mm framing wood from pallet deliveries this will be used as strengthening throughout the build, but whilst planning my local wood merchant mentioned they do cnc flat sheet cutting so I have asked for a little cutting.
- cnc sarah2.jpg (20.77 KiB) Viewed 1584 times
2 of each from a 25mm sheet, the wheel covers door surround and a bracer / decoration for the front.
oh and getting sketchup to output a dwg file after your trial has expired...pain in the neck but i found a solution from NB70 on github sketchup-dxf-stl-exporter
to stick it all together
Aerodux 185 Resorcinol Wood Glue
Liquid phenol-resorcinol resin adhesive for wood. A two-part system which provides a waterproof, structural bond.
Aerodux 185 is a 2 Pack resorcinol resin adhesive. Totally waterproof, resorcinol resin is recommended for use not only in structural timber applications but also for demanding and critical applications such as fire doors. Used extensively for bonding difficult timbers and can also be used to bond materials such as expanded polystyrene, plastic laminates, natural rubbers and some sheet metals. Can be used if required in hot pressing applications.
Mixed by weight. Ratio of mix 5 parts resin to 1 part powder.
its mightily expensive but I have glued stuff with it before and it does everything it claims so its on the list.
After reading and reading other builds, there was one must have tool to start the game off.
round 1
the Impakt P1 Portable Pocket Hole Jig VS Kreg R3 Jr. Pocket Hole Jig
FIGHT!!!
They are both pretty similar, both included:
•Pocket Hole Jig • Standard 3/8 Pocket-hole bit with depth collar and Allen wrench • 6-inch #2 square drive bit • 50 screws • instruction manual
both have the same capability range.
the Impakt P1 has a magnetic clamp base and is cheaper...
the Kreg R3 has metal drill guides and a Lifetime warranty.
the deal maker for me, after a little chat the supplier was willing to throw in a screw kit with the kreg if I bought one with the clamp.
We have a winner!
