Tom & Shelly's build
Re: Tom & Shelly's build
Postby eLink » Mon Apr 12, 2021 10:48 pm
This journal has been a great inspiration. I'm glad to see that it's finally finished and you can start enjoying it! :applause:
eLink
Images: 142
Postby western traveler » Tue Apr 13, 2021 12:27 am
It has been great following your build.
western traveler
Images: 264
Finished!
Postby noseoil » Tue Apr 13, 2021 8:12 am
Great job on the build guys, looks like it should be rolling well into the future with many miles of smiles. Nice to see a good design well-executed & completed. It's always worth the wait, but now the fun really begins. Hope to see you up here soon, on one of your trips!
Let us know what NM motor vehicles says about a license plate & how they approach it for inspection. I'll be curious to see how it goes & what they're looking at on a build. I still need to transfer ours over from Arizona, but with the permanent plate, I'm reluctant to spend more money...
137905
noseoil
Images: 669
Postby Tom&Shelly » Thu Apr 15, 2021 12:55 pm
Thank you all! This has been a great deal of fun, a wonderful learning experience, and just a little frustration once in awhile. (A bad day in the wood shop beats a good day at work, at least for the times I worked at a desk!)
Can't wait to try her out. Tim, we hope we can make it up there sometime in the next month or so. We'll let you know.
We registered it this morning. They did not inspect at all (we didn't even have it with us--it was at our mechanic having passenger tires installed). The other day we took it to the trailer manufacturer and he wrote us a front dated invoice and manufacturer's certificate, and those and my license (for ID) were all MVD needed. These days, we did need to make an appointment at our (rural) MVD a few days in advance.
We didn't need weight for registration, but I was curious so we took her to a station and it came to 1800 lbs with water and camping gear (we took the water, then dumped it on the way back to check handling both ways--no difference--great each way). So we didn't quite figure the tongue weight in the same configuration, but ignoring that: 208/1800 = 11.5 %, so we seem to have done well.
Too much running around to take pictures this morning, which is unfortunate, because it was a rare overcast day. Hopefully, we can get some under those conditions soon.
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Postby noseoil » Thu Apr 15, 2021 2:03 pm
Great news on the license plate. How much was it for the plate & registration, & for how long (year to year, permanent, like Arizona or)?
Socked in here in Raton today as well. Was out in the shop earlier on some stuff, but not pouring concrete today for another obelisk until it's a bit warmer. The mold worked well enough.
164828
137905
noseoil
Images: 669
Postby Tom&Shelly » Thu Apr 15, 2021 9:18 pm
noseoil wrote:Great news on the license plate. How much was it for the plate & registration, & for how long (year to year, permanent, like Arizona or)?
Hi Tim,
Nice obelisk!
For a permanent plate: Vehicle excise tax: $83.96, Original permanent registration: $41.50, Vehicle Title Fees: $5.00, Credit card fee: $1.55, and Village of Tijeras surcharge fee: $10.00. Seems like some shady fees there, especially since they only take credit and debit cards, but at least it was quick and easy.
No choice on plate type. This time it was the traditional yellow one. When I registered our Harbor Fright trailer in 2007 they gave me a balloon plate (ugly! But then I know what balloons really look like).
Tom&Shelly
Images: 2021
Postby Tom&Shelly » Thu Apr 15, 2021 9:32 pm
Clouded up again this afternoon, so when we got the teardrop back from our mechanic with a brand new set of passenger tires, I left it out and took a few pictures:
164839 164838 164837
164836 164834
164833 164832 164842
I call the last one "Does this license plate make my a$$ look fat?" No one told me that when you take a picture of the back of a Benroy, the hatch should be open. :lol:
Tried a few books in the bookcase and they rearranged themselves, but all stayed in their little area
164840
Guess I should have taken the picture before straightening them up. The issue is several different sizes in there so the adjustable back bar has to be set for the big ones. May have to keep the same size books in there. Read all of Tony Latham's books, so I have a Tony Hillerman in there for evening reading--inspiration for camping in Dine (Navajo) country. I'm saving a stack of Louis L'amour for longer trips later in the Summer.
It looks like the sliders slide around as we drive (again, I should've take the picture first--this is so you know what I'm talking about). May have to come up with some sort of latch
164841
But back in the galley the water jugs stayed put, and the Coleman stove and nested cook kit and dutch ovens all seem to stay in more or less one place.
Tom&Shelly
Images: 2021
Postby S. Heisley » Fri Apr 16, 2021 4:35 pm
:thumbsup: Looks Great! Thanks for sharing the journey of your build. :applause:
Postby Tom&Shelly » Sat Apr 17, 2021 4:31 pm
S. Heisley wrote::thumbsup: Looks Great! Thanks for sharing the journey of your build. :applause:
Thank you Sharon.
Tom&Shelly
Images: 2021
Postby Tom&Shelly » Sat Apr 17, 2021 4:43 pm
Got the home base power installed
164853 164849 164852
I used 3/4" aluminum angle for the entire thing. If I do it over, I'll use 1" or even 1.5" for the pieces against the wall, since they flexed more than I expected. Installed the panel at about 45 degrees, which my calculations suggest should yield good performance year-round. I carefully installed the panel a few inches from the wall so it won't catch too much shade from the overhang.
The wires fit nicely through a gap between the wall and the door.
The wires were a little stiff to run straight to the trailer plug, so I built a charging station out of junk
164850
Included a fuse because I had an extra fuse block, and also a voltage meter that I was going to install in the teardrop before they invented the AiLi columb meter. I don't want it on all the time so I included a push button from my Dad's junk box.
164851
It's partly cloudy with snow flurries today, but took that picture when the Sun was behind thin clouds. Amazed me that it would drop to about 14 volts for several seconds, even though I didn't notice any change in brightness; if indeed that's due to the weather and not something in the circuit through the PWM controller. I'll go and figure that out one of these days. :thinking:
Tom&Shelly
Images: 2021
Postby Tom&Shelly » Wed Apr 21, 2021 5:30 pm
Still a little cool for camping in the mountains of New Mexico (without heat in the teardrop). Plus we had a few personal matters to attend to. Maybe in a week or so...
In the meantime, I put in the counter light, complete with an upper shelf to hold things while in camp
164895 164900
Also included a little place to store a few items for checking out the shore power connection
164896
The thing on the left is an Altoids can. I told Shelly we could suck on the mints to calm our nerves while the tow truck was on the way. She pointed out it was fairly stressful this morning, and, if we sucked on them now, I could put some spare fuses in the can. So that's what we did.
I was going to put a Harbor Fright meter in there, but decided it made more sense in the tool box in the truck. After all, that's where we're more likely to have wiring problems (because I didn't do those!) ;)
Have a few square tuits, but when I get a round one I'll take some scrap Baltic birch and make something to hide the wires, and hold a lid for the storage bin.
I think this is a bit "gimmicky", but I made red/amber/white counter lights
164897 164898 164899
the idea being red to preserve night vision, amber to dissuade bugs, and white if we actually want to see what color the food we're preparing is. Bright as the counter lights in our cabin kitchen,
Tom&Shelly
Images: 2021
Postby Tom&Shelly » Sat May 01, 2021 3:01 pm
We had our shake-down campout 29 April - 1 May (this morning). Went to Bandelier National Monument, Northwest of Santa Fe next to Los Alamos National Laboratory, and about two hours from us.
We stayed at bandelier's "Juniper campground":
165033 165035 165075
Nice place--very clean, flush toilets, and dish cleaning sinks with hot water.
All went well with Cabin Fever. Everything worked as planned. We ended up using about 6% of our battery capacity
165074
After a two hour return trip, that was halfway refilled from the TV. I think it was still too full to take much more current. Anyway, at that rate, we could go for about two weeks and not deplete the battery more than halfway. Of course, it was still daylight when we made dinner so we didn't use the galley lights, and we didn't try out the DVD player.
Towing the trailer went real well up mostly paved highways and secondary roads. Only problem was after we got home and backing it into the garage. Lots of strange noises from the trailer brakes, and when finished the hubs were hot (they were cool the whole trip up). So we have to investigate that some more.
My camp cookery needs practice. I tried out corned beef, canned peas and carrots, sliced potatoes and tomato soup (we call it Irish scallop for some reason) in a dutch oven
165038
The part we ate tasted fine, but the coals must have been too hot for a lot of it, and we had some burned to the sides and bottom. Anyone know how to keep it cooler, or should I have taken it out sooner?
That was our first dinner, and I also screwed up the eggs for the first breakfast, trying to fry them on an aluminum pan over a Coleman stove we can't really adjust. After that, Shelly made the second dinner and this mornings breakfast (egg sandwiches) with more success.
Spent some time yesterday hiking (less than 3 miles round-trip) from the visitor center to the "Alcove House" 140 feet above the valley floor. The cliffs are made of volcanic tuff, which the ancestral Pueblo carved out and added to, to make their homes.
165037 165045 165044
165056 165054 165067
165069 165072
I only get nervous on the ladders when gripping the loose rungs. Luckily, the Ranger assured me those had all broken off last week.
I hope we did not dis-please the spirits!
165047
Tom&Shelly
Images: 2021
Postby noseoil » Sun May 02, 2021 7:36 am
137905
noseoil
Images: 669
Postby Tom&Shelly » Sun May 02, 2021 9:48 am
noseoil wrote:https://i1.wp.com/scoutingmagazine.org/wp-content/uploads/2016/08/CoalConversionChart.jpg?ssl=1
Thank you Tim!
Think I need to print and laminate this to take with us. I clearly had too many briquettes under the oven.
For the Coleman stove, I'm thinking either we buy a Partner Steel stove (as Tony Latham uses) or I rebuild the Coleman with some better regulator valves to give us more adjustment.
Tom&Shelly
Images: 2021
Postby bdosborn » Sun May 02, 2021 6:57 pm
Tom,
That's way too many coals. We use the 3 up 2 down method for ~325F. Add 3 to the dutch oven diameter for the number of coals on the top. Subtract two from the dutch oven diameter for the number of coals under the oven. When you can smell your food it's done. Works every time.
Images: 776
Users browsing this forum: No registered users and 24 guests
