Thankfully, I have been able to work from home during the epidemic. But I still cannot seem to find enough time to work on my camper.
I had intended to get it inspected at DMV as a stock flatbed trailer. But since that office is closed indefinitely, I will just build it and take my chances once it's done.
Went ahead slid the springs back 6", flipped the axle and checked the fit for the new 15" wheels. Interesting to note that the bed height ends up about the same as stock.
- Underslung.jpg (166.78 KiB) Viewed 3010 times
What is the consensus for keeping the stock M10 U-bolts for the underslung axle? I noticed that some people are beefing them up.
I discovered this back when I was assembling the frame...Always measure twice, or three times...
- Axle.jpg (114 KiB) Viewed 3010 times
Since the frame width had been reduced by 2", I figured I would simply drill new center-bolt holes 1" inboard on each side. Turns out that the stock locations were off-center by almost 1/2 inch! So I had to grind one of the holes a little wider.
