bdosborn wrote:Thanks, I found it on Amazon and saved it to my trailer wish list. I jackknifed the truck too far and punched a hole in mine.
Tongue Box
KTM_Guy wrote:campbellinaz wrote:KTM_Guy wrote:campbellinaz wrote:Enjoying following your build Tony! I’m currently in the midst of a build and pricing out sheet aluminum in the Phoenix area is crazy expensive! I’m in need of 5x10 sheets which I’m told are only available in .063 and I’m seeing prices just shy of $300/sheet . So I’m looking at “liners” now as they are much less expensive. Although glass/epoxy is far more time consuming it can’t be as expensive as 3-4 sheets at $300 a copy.
Don’t go to IMS in PHX, I found a place and got .040 5X10 I think was $60 a sheet. Can’t remember the name right now. It was west of downtown.
Todd
Todd, I’m really interested if your able to figure out where you got the aluminum. I’m afraid the tariff saga has changed buying aluminum forever.
I bought from
Coast Aluminum and Architectural
4455 W MAgnolia St
Phoenix, AZ 85043
602-278-5052
They mostly deal with truck load orders but didn't seem to mind my small order.
Another place to check is Davis Scrap just north of Sky Harbor. Some times they will have thin gauge aluminum sheets but mostly 16 gauge and up. Still a fun place to check out. The other week I was looking around in the yard and there was about 10 pieces of 20X20X12 blocks of aluminum.
Todd
tony.latham wrote:
The devil is in the details.
p.s. that's done with tissue paper
Can you please explain how you did that with tissue paper
tony.latham wrote:Can you please explain how you did that with tissue paper
Get your final design printed on regular paper and then tape the tissue paper over it. I use just enough tissue to cover the print plus room for tape. Stick it back in the printer and push the button.
Wet the spot out with the same varnish you used on the wood, set it in place making sure it's level and then saturate the tissue paper.
The challenge is finding the right tissue paper. The first stuff I tired wrinkled when wetted out. I can't give you a brand since I found this stuff in with our gift-wrap papers. I suggest you finish a piece of scrap plywood with your varnish and then test your printed tissue paper on it.
Thanks Todd!KTM_Guy wrote:campbellinaz wrote:KTM_Guy wrote:campbellinaz wrote:Enjoying following your build Tony! I’m currently in the midst of a build and pricing out sheet aluminum in the Phoenix area is crazy expensive! I’m in need of 5x10 sheets which I’m told are only available in .063 and I’m seeing prices just shy of $300/sheet . So I’m looking at “liners” now as they are much less expensive. Although glass/epoxy is far more time consuming it can’t be as expensive as 3-4 sheets at $300 a copy.
Todd
I bought from
4455 W MAgnolia St
Phoenix, AZ 85043
602-278-5052
Todd
Tony, what height did you end up making your platform dolly? You said 19", but were thinking of cutting it down.
..not be a traditional teardrop, but a 5x5x11 foamie....
So why #4?
Just because... (that's my story for now and I'm sticking to it). I'll expand on that tale down the road but it's not because we need a new teardrop and it's not because I'm going into the biz.
tony.latham wrote:If you scroll back to my first entry with this post, I wrote:So why #4?
Mystery unveiled:
It was a challenge to keep the price down, but I'm pleased.
