My 100% garage built teardrop
Re: My 100% garage built teardrop
Postby ricky herbold » Sat Oct 12, 2019 2:56 pm
This is the edge detail I came up with for all of my cabinet doors. A 3/8 rabbet on both the doors and face frame. It was alot more work than just cutting a hole but it gives you a positive stop for the doors and holds them flush all the way around. I believe it was worth the extra effort.
ricky herbold
Postby ricky herbold » Sat Oct 12, 2019 3:08 pm
I didn’t really show how I concealed all of my electrical wiring. I made the backsplash so it could hinge down. The Bach splash is made from 3/8 BB to keep it both stiff and light and mounted on self closing cabinet door hinges. This cavity will also be where I plan to run all the water and vent lines as well as the propane line to the water heater.
ricky herbold
Postby featherliteCT1 » Sat Oct 12, 2019 5:28 pm
Your skills and work are awesome! :applause:
featherliteCT1
Postby NevadaBlue » Sat Oct 12, 2019 6:11 pm
Wow, very nice work. I like the hidden, yet accessible, utilities. That hidden space under the floor is great too. Must consider that one.
Ken
NevadaBlue
Postby Bigforkg » Thu Oct 24, 2019 1:23 pm
Nice build! :worship: Im wanting to build a squaredrop (Grasshpper) with a steel body frame like yours. Did you seal up the plywood before the skin? How did you attach the skin?
Bigforkg
Postby ricky herbold » Fri Oct 25, 2019 8:56 am
Bigforkg wrote:Nice build! :worship: Im wanting to build a squaredrop (Grasshpper) with a steel body frame like yours. Did you seal up the plywood before the skin? How did you attach the skin?
I did seal the plywood prior to skinning. I used polyurethane. Not sure if that’s the best or not but I figured better than nothing.
For the aluminum skin I used trempro caulk around the perimeter and the door openings. Then all the edge trim is caulked and screwed on all the way around.
Not sure if it’s the correct way but I think it turned out great.
Bigforkg I look forward to following your build. This is my first and I already want to start another one. Or two?
ricky herbold
Postby ricky herbold » Wed Nov 13, 2019 8:59 pm
My new plates finally came in.
ricky herbold
Postby ricky herbold » Sun Nov 17, 2019 11:25 am
My boss gave me a 16 gallon water tank that was left over from a sprinter build we did for him. Time to fabricate something to mount it under the trailer. Image
ricky herbold
Postby ricky herbold » Sun Nov 17, 2019 1:43 pm
Ok. Here is what I came up with. A basic angle iron frame around the bottom of the water tank. The tank will be bolted up tight to the bottom of the trailer. I added a flat strap down the middle to help support the weight of a full tank. Image
ricky herbold
Postby ricky herbold » Sun Nov 17, 2019 1:44 pm
Here it is with the tank inside. It’s upside down on the table.
ricky herbold
Postby ricky herbold » Sun Nov 17, 2019 1:47 pm
Mounted under the trailer ready to run the fill, vent, drain, and supply lines. I still need all of the bulkhead fittings and the vent and fill cap. Time for a amazon order. ImageImage
ricky herbold
Postby ricky herbold » Sun Nov 17, 2019 2:16 pm
One thing I added that I think will be super convenient both while driving and at camp are some rock lights. I have 3 on each side and 1 in the back. The lights are wired into the 7way plug and turn on when the tow vehicle is put into reverse. Once at camp you unplug the trailer from the truck and plug it into the receptacle on the tongue box. You can then either turn on the rock lights or the running lights. Probably not needed but I think it will be neat. ImageImageImageImage
ricky herbold
Postby twisted lines » Sun Nov 17, 2019 2:55 pm
ricky herbold wrote: I still need all of the bulkhead fittings
Keep your findings updated please you made me think about holes a few days ago :thinking:
Still looking great.
Racking up; And Rapin foam
twisted lines
Postby featherliteCT1 » Sun Nov 17, 2019 5:01 pm
Beautiful work! :applause:
featherliteCT1
Postby NevadaBlue » Thu Dec 19, 2019 9:43 pm
How did you get the rock lights to come on when reversing? I just bought a third brake light with ‘cargo’ light. I would like that white light to come on when I back up.
Ken
NevadaBlue
Users browsing this forum: Google [Bot] and 34 guests
