5 x 8 benroy
5 x 8 benroy
Postby Simple_Abound » Sat Feb 03, 2024 7:56 pm
The build has begun. I managed to cut everything correct so far. My goal is to make the galley as small as possible. The countertop will be 18" deep and 18" off the floor and 38" off the ground. There is a small lumber yard 45 minutes away that has baltic birch. I also didn't realize 3/4" foam board was going to be difficult to get, I'm considering just cutting 1 1/2 in half. I'm finding out being short is going to have it's advantages.
173044173041173045
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby edgeau » Sat Feb 03, 2024 10:34 pm
One of the joys of building is you can make it suit your needs. Good luck and sing out if you need advice, there are lots of friendly and knowledgeable folk on the forum.
Sent from my Pixel 6 using Tapatalk
edgeau
Re: 5 x 8 benroy
Postby Simple_Abound » Sun Feb 04, 2024 10:40 am
After sleeping on how to seal the galley floor, I've come up with my solution. Instead of having the galley door meet the bottom of the floor, I'm going to extend the hatch 2 1/4" to extend beyond the galley door. It will require more work but I think it will be a better solution to keep the water and weather out. It will also make the galley 2 1/4" deeper. There is so much information on this site, it sure makes it easier to build with all of it.
173054173053
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby tony.latham » Sun Feb 04, 2024 11:02 am
The original Fredrick's style hatch–-as you may know--mated with the top of the floor and that's how I did it back in 2009. In cold, wet weather, the bottom of the hatch would sometimes freeze to the floor--it was a problem. Silicone spray "fixed" the freezing issue.
It works much better if the hatch seals to the end of the floor. The floor stays dry. (I still believe in sealing the floor with epoxy.)
Re: 5 x 8 benroy
Postby Tom&Shelly » Sun Feb 04, 2024 12:41 pm
Tony had mentioned this about the time we were getting ready for our wall build. Quick redesign so the wall met the floor; later a hatch design that met the floor at the back, and no regrets after 3 years of camping in rain (and shine)!
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Re: 5 x 8 benroy
Postby Simple_Abound » Sun Feb 04, 2024 12:43 pm
Thank you for the picture . I think the hatches will work better, they seam to be a more constant fit to keep the weather out of the galley.
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby tony.latham » Sun Feb 04, 2024 1:27 pm
I think the hatches will work better...
Dust and waterproof with no spring-back if done correctly.
Re: 5 x 8 benroy
Postby Simple_Abound » Sun Feb 04, 2024 7:48 pm
I'm taking advantage of the nice weather in Minnesota while I can. I wasn't lifting another full sheet of 3/4" plywood on the saw horses. I managed to get the outside walls and skeleton walls cut. The 3/4" plywood now weights about 20 pounds and plenty strong , there were listed at 66 pounds. They are plenty strong, definitely easier than using 1 x 4's. The doors are 32" x 26" and set back about 16" and 3" off the floor. I will be making my own doors. If I can get the side walls glued together this week I will be happy with the progress. Still need to get more plywood and insulation.
173055173056173057
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby Simple_Abound » Sun Feb 04, 2024 10:03 pm
I've discovered that 3/4" foam board insulation is unobtainable in my area, unless I want to order 60 sheets. I have some leftover 1 1/2 from a previous build that I'm going to try to cut to size. It's going to be a mess but I don't like the idea of using polystyrene that's used for packaging.
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby Tom&Shelly » Mon Feb 05, 2024 8:50 am
Simple_Abound wrote:I've discovered that 3/4" foam board insulation is unobtainable in my area, unless I want to order 60 sheets. I have some leftover 1 1/2 from a previous build that I'm going to try to cut to size. It's going to be a mess but I don't like the idea of using polystyrene that's used for packaging.
We solved that problem by making a hot wire cutter with a 6 foot wand. https://www.tnttt.com/viewtopic.php?f=50&t=70278&start=15
Lots of Youtubes and other stuff on the web about making those, if you're interested. No foam dust!
Tom&Shelly
Images: 2021
Re: 5 x 8 benroy
Postby Simple_Abound » Mon Feb 05, 2024 10:24 pm
That looks like a fun project and definitely safer than the torch idea that went through my mind.
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby Simple_Abound » Mon Feb 05, 2024 10:37 pm
A little bit of progress at a time. The skeleton is now glued to the exterior walls, I don't skimp on glued. The walls now weigh 40 pounds a piece. I have not decided if I'm going use 1/4" or 1/8" for the interior walls. I will not be using luan, my first build has it and one wrong move and you have a nice conversation piece. Tomorrow I'm hoping to start on the floor.
173058173060173059
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby Simple_Abound » Wed Feb 07, 2024 9:16 pm
More progress the last couple of days. The floor is complete, 1 x4's length sides 1 x 3's width sides. There's 1/4" bcx plywood on both the top and bottom. The inside 1/8" plywood has been cut with the holes pre drilled for screws and decorative washers. The template I made to show the skeleton came in handy for marking the holes. I'm hoping to get the 3rd coat of stain on the interior walls and then I can complete the skeleton walls.
173065173061173063173062
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby Simple_Abound » Thu Feb 08, 2024 10:30 pm
The walls are put together. All that work putting those screws in to remove most for the door frame and cabinets. 173066173067
Simple_Abound
Images: 85
Re: 5 x 8 benroy
Postby tony.latham » Thu Feb 08, 2024 10:33 pm
What did you end up using for foam board?
