A Roux Question (or two)
Your recipes which you'd like to see in the T&TTT Cookbook #2.
Moderator: Mike B
Postby tinksdad » Wed Jul 23, 2008 10:20 am
In the past whenever I made my roux for gumbo, I did it in the bottom of the stock pot and basically just enough for that pot of Gumbo. I would always wimp out when it reached peanut butter or caramel color and toss in my onion, celery and bell peppers to stop the roux from cooking further.
Today I decided to go for the gusto and make a bigger batch of roux just to have on hand (in a glass container in the fridge); plus I wasn't stopping at caramel!! It's the first time I have ever tried doing a roux in my CI 12" skillet as well. Started out with 2 cups of oil and 2 cups AP flour. Stirred constantly. I was resolved to pee my pants at the stove if the necessity arose just so as to not stop stirring!! I got it to dark chocolate before I removed the skillet from the heat. Kept stirring while the pan cooled; and the final color is almost black coffee.
Question(s):
How can you tell if it's burnt?? If you scorched it, the smell would be obvious. It had no smell, no black specks floating while cooking, no visual tell tales at all.
What should a roux this dark, without the veggies, taste like? This is a first for me at this color, so I am clueless. It doesn't taste burnt. It's kind of nutty, tastes a little bit like toast.
And finally (for now), and I realize it's probably just a personal thing with every cook, what color roux do you think makes the best Gumbo? I usually do chicken and andouille, not a fan of seafood gumbo.
I guess the acid test will be to make a small pot later and see if I like it.
tinksdad
Images: 155
Postby asianflava » Wed Jul 23, 2008 11:25 am
I'm no expert by any means, but from what I've been told, it will smell burnt if you went too far.
asianflava
Postby Lucky489 » Wed Jul 23, 2008 12:04 pm
Well since you say it tasted nutty and like toast. You made a perfect roux. For color I make my roux's with a dark chocolate colr and typically take almost an hour to get the color I want.
Lucky489
Postby madjack » Wed Jul 23, 2008 1:40 pm
...as a long time Cajun style cook, it sounds like ya got it just about perfect...when you screw it up, you will know by the burned/scorched smell/taste, which is usually accompanied by your smoke detector going off :D :lol: ;)
A computer lets you make more mistakes faster than any invention in human history - with the possible exceptions of handguns and tequila.
most all personal problems can be solved with the proper application of high explosives
Postby Mauleskinner » Wed Jul 23, 2008 6:08 pm
madjack wrote:...as a long time Cajun style cook, it sounds like ya got it just about perfect...when you screw it up, you will know by the burned/scorched smell/taste, which is usually accompanied by your smoke detector going off :D :lol: ;)
Do they make smoke detectors with an "about to go off" warning? Sounds like that would help my cooking a LOT! :applause:
Hmmm...maybe now I know what to invent so I can be rich...:thinking:
David
Mauleskinner
Postby Eddielbs » Thu Jul 24, 2008 7:48 am
I like a little darker Roux for my Chicken and Sausage gumbo than the one I use for my seafood gumbo. All i can tell ya is the time it takes to make the difference between a lighter and darker Roux is that its about the same as the time it takes to drink half a bottle of beer while stirring. So that translates to "Not Long" ;)
"Some Minds are like cement, A grey matter that is thoroughly mixed up and permanently set."
Eddielbs
Images: 120
Return to T&TTT Cookbook #2
