Page 2 of 2
Re: RV Stove VS Camping Stove
Posted:
Sun Aug 26, 2018 1:01 pm
by Socal Tom
SunTrekker wrote:Shadow Catcher wrote:We have an Atwood three burner and Nancy has no complaints, the true test
@Shadow, just trying to figure out stoves right now as well. How often do you use all three burners?
Everyone else....2 burners or 3 and why?
I just have 2 burners, cause I wanted the camp chef oven, and it came with 2. There are times when both are full and a third would be nice, but most of the 3 burner stoves have them so close together I'm not sure you can really use them as 3 burners. I think if I needed a third burner frequently I would use one of these.
https://express.google.com/product/9657 ... mpaign=gsx
Posted:
Sun Aug 26, 2018 1:03 pm
by SunTrekker
Nice! Specially at $19.
Thanks!
Posted:
Sun Aug 26, 2018 1:46 pm
by Ottsville
I pretty much never need more than two burners. Most of the time it's just one but that really depends on how you cook. Camp chef two burner is my go to, although I've been looking at one of those single burner butane ones posted above. I foeget the manufacturer, but somebody makes those that run on either butane or propane.
Posted:
Mon Aug 27, 2018 7:21 pm
by KTM_Guy
If you have an Asian market you can find those butane single burner stoves cheap. And the butane fuel is so much cheaper than anyplace online. I have also seen them in double burner stoves. Great little stoves, but they struggle above 11'000 feet.
Todd
Posted:
Wed Nov 28, 2018 4:21 pm
by Andrew Herrick
KTM_Guy wrote:Just an FYI the Partner Steel stove was mention above and they are great stoves, but they need to use the the supplied regulator. It runs at a higher pressure than most camp stoves or other propane things in an RV. I'm getting ready to bit the bullet and order one soon.
Todd
Can attest to that. A few months ago, a representative at Partner Steel told me their burner is 27 PSI. For reference, the low-pressure side of an RV propane system (11 WC inches) is roughly 0.5 PSI. I think the typical "Coleman" camping stove runs at 10-15 PSI (don't quote me on that). So, just to make that clear: Almost no stock camping stove will run properly connected to a low-pressure propane system. Most have a built-in pressure regulator and must be connected to a high-pressure source (tank or quick-connect fitting), which IS a safety concern. Thankfully, since most cooking in a teardrop takes place outdoors, the safety risk is mitigated.
Posted:
Fri Nov 30, 2018 3:16 pm
by Shadow Catcher
I use a two stage regulator and it feeds a gas grill, three burner cook top and a 6gal water heater. "The outlet pressure is 11"WC and has a 160,000 BTU/hr capacity."
Posted:
Sat Dec 01, 2018 11:55 pm
by Wolfgang92025
I have both 2 & 3 burner Coleman white gas.
Last 5 years I have only used the 2 burner stove.
It's lighter and takes up less space.
Last, think about how often you use 3 burners at the same time at home?
Posted:
Fri Feb 15, 2019 10:40 am
by jwlambert
Camp Chef everest two burner with oven. Thats my fave.. Failry affordable and very well built and most of all.... it is reliable!
Posted:
Sat Jul 06, 2019 2:35 pm
by mexican tear
I have always loved this stove. Bought my first when it was just a Mexican stove.
https://www.cabelas.com/product/Camp-Ch ... s?slotId=6
Posted:
Thu Jul 11, 2019 7:04 pm
by Shadow Catcher
We use the three burners not often.
