Is a used propane tank really cheaper?
Postby dh » Sun Jun 12, 2011 1:47 am
I found a 5lb propane tank for $5.00 at a flea market, and brought it home. I cracked the valve, and it has no pressure in it, and is rusted a bit. Where am I going with this? I am going to assume it was neglected, period. I know it needs purged, and I want it inspected before it goes back into service, and would like to re-paint it. Will this be cost efective, or would I be bettr off throwing $90.00 at new one?
dh
Postby madjack » Sun Jun 12, 2011 1:59 am
...if it has a round valve handle Vs a triangular one, most refill stations won't refill it...you would have to have it inspected, tested and the valve changed out...I don't know what refurbishment would cost but what ever it cost, you would still have a used (and expensive) tank when done..............
p.s. I was gonna go with one of the smaller tanks BUT because certification is only good for 5yrs, I opted to use a 20# tank and just take it in for exchange when it's certification expired............mj
Re: Is a used propane tank really cheaper?
Postby Dale M. » Sun Jun 12, 2011 9:59 am
dh wrote:I found a 5lb propane tank for $5.00 at a flea market, and brought it home. I cracked the valve, and it has no pressure in it, and is rusted a bit. Where am I going with this? I am going to assume it was neglected, period. I know it needs purged, and I want it inspected before it goes back into service, and would like to re-paint it. Will this be cost efective, or would I be bettr off throwing $90.00 at new one?
Costco has new 5 gallon tanks (20 lb) $29.95 ( just noticed them last week at that price).... Whoever is quoting you $90 is ripping you....
http://www.google.com/search?q=20+pound ... 0+pound+pr
Interesting price comparison....
http://www.gasgrillsnow.com/viewPrd.asp ... &ref=gbase
Vs..
http://www.ruralking.com/20-lb-type-1-p ... 3430303534
It's illegal to refill 5 gallon propane tanks that do not have OPD valve (10 -15-20-50- gallon tanks are not restricted to OPD valve)
New replacement OPD valve for old tanks are around $20 -30 ....
http://www.protanksupply.com/propane-opd-valves.asp
Propane tanks are certified for 12 years after manufacture, and must be inspected and re-certified every 6 years there after..... Check date stamp(s) on tank safety collar...
Dale
Dale M.
Images: 18
Postby dh » Sun Jun 12, 2011 10:15 am
That wasn't a typo in the OP, a 5lb tank, not a 5 gallon tank. Find a MANCHESTER 5lb tank new for under $75, and I'll take it.
It doesn't need the valve changed out, and I can handle the re-paint, but how much is an inspection and purge?
The tank is dated 2006, so maybe I can just inspect for intrnal rust while I have the valve off while refurbishing tank.
dh
Postby Larry C » Sun Jun 12, 2011 5:47 pm
dh wrote:That wasn't a typo in the OP, a 5lb tank, not a 5 gallon tank. Find a MANCHESTER 5lb tank new for under $75, and I'll take it.
dh,
I have a Manchester 5# bottle that has the old valve. It is in NEW condition, only been filled a couple of times and stored in a clean dry location (no rust) but it's mfg date is 1994 even though I bought it "new" in 2004. Do you know what it will actually cost to get it re certified? I can probably get the new valve and install it myself, but do you know what is involved in re certification? Does it have to be hydro tested? I can do that, but can't certify it. (at least not for a propane tank)
This 5 lb bottle is by far one of the very best camping purchases I have ever made!! It's truly a no brainer....... It's 5) 1# mini bottles at the refill price of buying just one!
Larry C
Larry C
Images: 78
Postby slowcowboy » Sun Jun 12, 2011 5:51 pm
your biggest problem will be the rust. they will not fill it if there is rust.
its going to cost you more to have one refuburshed than to just buy a new one.
I got my 11 pounder for 50 bucks at ace hardware and its a manchestor.
you can get them refurbershed. I have no clue on if you can get a propane company to repaint it though.
I have been trained though in purging and re- certification.
I can say theres going to be a problem with the rust getting it refurnshed.
you can get a new valve and its normaly about 30 bucks.
like I say rebuilding it can run up in cost.
90 is a rip off price and I think if you look around you can find one a heck of a lot cheaper. Try wally world yet? you might even try online. I would not be scared to give ebay a try.
you problem is the propane national safety boards standards for what they certify is real picky.
slow.
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby Dale M. » Sun Jun 12, 2011 8:15 pm
OK.... Lets do the seller is ripping you off again ( 5 lb size) .....
http://www.google.com/products/catalog? ... CG8Q8wIwAA
http://www.acehardwaresuperstore.com/pr ... /8248.html
Dale
Dale M.
Images: 18
Postby dh » Mon Jun 13, 2011 12:44 am
Ok, I did a little deeper research, a reinspection is visual, no dents, dings, or pitted rust, and a soap water leak test, and thats it. The date is stamped next to the manufacture date with an ''E'' for examined. Costs from $15 to $35 (from my online research). Purging costs from $5 to $35 and is either done by filling with vapor and releasing 5 times, or by vacuum. Also, purging is required on new tanks that are not prepurged by the manufacturer.
dh
Postby dh » Mon Jun 13, 2011 12:58 am
Looks like I can skip the inspection, make sure it isnt rusted inside and get purged and be good to go. The $90 is for a new tank, purging, first fill, and a 'complimentary' soap test, $75 just for the tanks, which isn't that much more than Dale's prices after shipping. How much pressure can a tank take? I'd like to pressure test the valve myself before I get it filled. I can put 150lbs of air pressure on it at home.
dh
Postby Larry C » Mon Jun 13, 2011 6:57 am
dh wrote:Looks like I can skip the inspection, make sure it isnt rusted inside and get purged and be good to go. The $90 is for a new tank, purging, first fill, and a 'complimentary' soap test, $75 just for the tanks, which isn't that much more than Dale's prices after shipping. How much pressure can a tank take? I'd like to pressure test the valve myself before I get it filled. I can put 150lbs of air pressure on it at home.
I believe the relief valve is set at 350. If that's the case, it probably has a 5 to 1 safety factor. Burst would be above 1750. However, I may be totally wrong on this. :lol:
Larry C
Larry C
Images: 78
Postby dh » Mon Jun 13, 2011 11:24 am
I think I worded my question incorrectly. How much pressuer will it take to properly pressure test the valve? Oh, before somebody brings it up, I'd use the paint gun tap, after the filter/regulator, and before the oiler. I also use different fittings and hoses for the paint gun, so the 'paint gun' air lines never get oil in them.
dh
Postby Dale M. » Mon Jun 13, 2011 7:20 pm
Larry C
I had a propane tech at local place where they test and refit tanks tell me 260psi..
Oh well...
Dale M.
Images: 18
Postby dh » Mon Jun 13, 2011 9:21 pm
Larry C
Oh well...
150 psi might not be up to spec, but still better than nothing before getting it filled.
dh
Postby Larry C » Tue Jun 14, 2011 6:57 am
Larry C
Oh well...
I said I might be totally wrong :cry:
Actually the tank rated pressure is stamped right on each bottle. My 5# bottle is 260, as you said, but I have and old (40 years) 20# bottle that is marked 350. I think originally they were all 350. I was told that several times over the years. My old old bottle is much heavier (empty) than the new ones (thicker).
Larry C
Larry C
Images: 78
Postby dh » Tue Jun 14, 2011 12:42 pm
I've read about this while researching the recertification process. As steel prices went up, tank wall thickness went down, as did the pressure rating.
Larry, when you hydro test a hose, how much pressure do you put on it?
dh
