Plumbing sink drain
Plumbing sink drain
Postby Oldragbaggers » Sat Nov 12, 2011 10:35 pm
Where would I look to find information how how to install a sink drain FOR DUMMIES. I have been googling all evening and don't find anything. I find plenty of places that sell all kinds of parts. But I need to know which parts I need and how to put them together. What I want to do is something like this.....
or this
http://home-and-garden.webshots.com/photo/1182548186034925867bbwZLn
I want a small sink that will drain to an outlet on the teardrop, like the one above, that can either be routed to a sewage system in an RV park if that's where I happen to be staying, or into a portable holding tank outside of the teardrop like in the above application.
What parts do I need. Where can I find a diagram of how to put them together? I have looked for books on the subject on Amazon also and didn't see anything that looked like it would contain the informaiton I am looking for.
Thanks!!
Becky
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby slowcowboy » Sun Nov 13, 2011 12:35 am
becky heres what I do.
I run from the bottom of my sink a rv p trap and a 6 inch flex hose to the side of my teardrops wall.
it then has a rv city water inlet fitting in the hall though a hole in the wall.
on that I hook a short piece of cut off garden hose about 12 inches long.
then I stick the end of the hose in a wally world blue 5 gallon water jug from the camping section.
the p trap srews on the end of my sink drain.
then the flex hose slips over the end and has a pipe clamp on it or a hose clamp.
then thats slipped over the end of the city water inlet end and its hose clamped on.
the hole cost. proublely less than 15 bucks.
parts readly availbe at any rv store. and the rv city water inlet is like only 4 bucks. the p trap comes with the flex hose and is maybee I don't not more than 12 dollars.
pretty simple and yes. thats my hole plumbing on my teardrop.
I dump the wally world jug and by sink water where ever I find a place to dump it.
even if its at home.
lot of the times I water a sage brush or a campfire to make sure its out.
slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
6000 Club
6000 Club
Images: 166
Postby Oldragbaggers » Sun Nov 13, 2011 8:30 am
Thanks for that reply Slowcowboy. That sounds like a good, inexpensive and simple solution. I like it.
Becky
Becky
Oldragbaggers
Images: 331
Postby hoytedow » Sun Nov 13, 2011 8:52 am
Slow gives good advice and here is a video showing how it is done up to a point.
Ignore the part about the garbage disposal.
http://www.youtube.com/watch?v=ipVMXq1t ... pVMXq1tx5c
Happy trails,
Hoyt
hoytedow
Images: 19
Postby slowcowboy » Sun Nov 13, 2011 9:30 pm
your welcome becky. its a pretty simple set up and works good. I have never had a problem or had to drain the sink to winterize other than a 6 gallon freshwater under the frame of my teardrop and a hose to a manaul rv faucet. theres no other plumbing on board.
all I do to winterize this syetem is to open the drain on the fesh water tank and forget about the plumbing. all the water from the sink is out instanly
when I pull the rubber stoper out of my drain on my sink.
the water in the sink goes into the wally world jug and its so easy to get rid of it any where.
you can dump it in a rv disposal station at any campground or any camp fire or what ever.
I have even took it home and dumped it.
It don't leak and it won't drip as it has a good cap with a gasket in it to sqrew on the end of the city water outlet when going down the road.
slow.
slowcowboy
6000 Club
6000 Club
Images: 166
Postby StandUpGuy » Sun Nov 13, 2011 9:51 pm
I obtained the sink I am using for my build on Craig's List. There are some existing fitting already mounted to the drain. I was under my sink cabinet this morning doing some plumbing and I looked at the fittings more closely. They are threaded to accept the female end of a garden hose. I too must work out exactly how I will drain my sink along with my shower. If it was only the sink I was draining I would a drain fitting through the floor of my trailer in the cabinet and simply screw a garden hoseto the exterior fitting and then in turn to my grey water tank.
My shower complicates things for me however. :crazy:
StandUpGuy
Re: Plumbing sink drain
Postby PcHistorian » Wed Mar 14, 2012 10:10 pm
@standupguy, use a garden hose "Y" fitting between the sink, the shower and the grey water tank. Or a "T" fitting. "Y" can give you more or smoother flow rate for a gravity system though, I would think.
Elf Cottage
Build Documentary
https://sites.google.com/site/pchistorian/home/hobby/camping/elf-build
Build Forum
http://www.tnttt.com/viewtopic.php?t=48462
Build Album
http://www.tnttt.com/gallery/album.php?album_id=42
progress is progress. (don't look a gift "progress" in the mouth.)
PcHistorian
Images: 198
Postby Dale M. » Thu Mar 15, 2012 9:12 am
A long time ago I used a stainless steel mixing bowl as a sink.... Just cut hole in bottom that was large enough to accept a drain assembly for a "bar sink"....Why "bar sink", because whole thing is smaller the "standard" sink drain....
Off bottom of drain assembly I just attached a length of poly hose that had a female garden hose connection on it and took hose through floor and let it hang a few inched below "van".... Used "short hose" to connect to catch bucket or what ever we were using for "gray water" at the time...
http://www.amazon.com/Junior-Basket-Str ... B001EMJBGM
http://www.amazon.com/Fox-Run-12-Quart- ... ing0ead-20
Yes there is some adapting involved, but then its all about the build...
Dale
Dale M.
Images: 18
Postby PcHistorian » Thu Mar 15, 2012 12:03 pm
Well, I need maximum diameter with minimum depth. (depth of sink plus drain elbow <= 4") Boy, I could use a 9x13 pan even then, little modification to the drain area slope with some basic pressure. Buy at salvation army for $0.50. Rim of wood. Drain as you say... of a basic screen and 1/2 inch fitting and elbow.
If you want to get REAL simple, I have been thinking of using a hinged fold down sink, that rests on top of one of those new kind of liquid laundry detergent jug. the ones with the caps that drain inside the bottle. Then when filled just go drain it, swap in a second one... Lots of possibilities there. If you are going that route and don't want to go "power faucet" yet, you can get one of those camping water bags with the spigot, that has a hanging point, opposite the spigot. Just hang it over the sink.
I now have an idea to have my fill point at the right front corner soffit/eaves... That would give me an access point, semi-hidden, with some elevation for the venting. I'm wondering now, we have the grey water storage and drainage. Even slip some chlorine down there for cleaning, is there grey water flushing? (pressure inlet -> flow through grey tank -> to grey drain?) to clear out any sediment of dirt?
location of this in my build documentary
https://sites.google.com/site/pchistori ... d#wtr-plan
FYI: I'm jumping almost same topic between two forums.
here: ( a new one )
viewtopic.php?f=54&t=43687
there: ( Plumbing sink drain )
viewtopic.php?f=54&t=47290&p=920552#p920552
The build is the thing.
Elf Cottage
Build Documentary
Build Forum
Build Album
PcHistorian
Images: 198
Postby pmowers » Thu Mar 15, 2012 9:22 pm
Have you considered a "hotel" pan like they use at the local buffet? A full-sized pan is 19.5x11.5 inches, and come in a variety of depths and sizes such as 1/2, 1/4, 1/8 etc, and from 1-6" deep.
I would check out some of the local restaurant supply houses, a lot of the time restaurants open and then close before the ink is dry on the purchase agreement, and they have a large selection of used equipment. A new full pan 3" deep can be purchased online for about $20, used much less.
Growing old is mandatory, growing up is optional.
Build log:http://www.tnttt.com/viewtopic.php?f=42&t=51193
pmowers
Images: 43
Postby Oldragbaggers » Fri Mar 16, 2012 9:46 am
pmowers wrote:Have you considered a "hotel" pan like they use at the local buffet? A full-sized pan is 19.5x11.5 inches, and come in a variety of depths and sizes such as 1/2, 1/4, 1/8 etc, and from 1-6" deep.
These buffet style pans are available at Sam's Club for not too much, and that's an excellent suggestion!! I wish I had thought of it before I bought my sink.
Becky
Oldragbaggers
Images: 331
Postby PcHistorian » Fri Mar 16, 2012 2:49 pm
"local restaurant supply houses,"... hmmm...
:thinking:
Elf Cottage
Build Documentary
Build Forum
Build Album
PcHistorian
Images: 198
