Thermix wall heater
Thermix wall heater
Postby Treeview » Thu Dec 22, 2011 8:17 pm
Yesterday I picked up a furnace, range/oven and a Thermix wall heater.
The furnace is one that Suburban recalled so I might have bought a pile of parts and not a useable furnace. Next week I'll get into it and see if it had the recall fixed.
The 4 burner range/oven look useable. Cleaning will happen.
In the pile of extras there is a Thermix wall heater that looks like this:
http://tinyurl.com/thermix-heater
What are the specs on the unit? BTU output?
If there is enough output I might go with the Thermix rather than the furnace. No electrical use and quiet. It might not put out as much heat in the volume that a furnace would but on of my design criteria is simple and repairable.
Thanks,
Treeview
Images: 30
Thermix wall heater
Postby Nite Ryder » Sun Feb 05, 2012 3:14 pm
You posted this question sometime ago, and I see no answers so far. The Thermix heater will work as far as putting out heat, but it won't put out as much as most furnaces. The good thing about a Thermix is that it doesn't need any electrical power to work like a furnace does. That means when you are stuck out in the Pucker Brush and there are no generators in the middle of the night and no power outlets, it will still heat your camper. One draw back is you need to have a vent open if you want to be assured of waking up in the morning. The furnace vents all exhaust outside (usually), but it does require a 12 DC power supply if it is the forced air kind of furnace that uses a fan. Help this helps answer your question.
If its got a cork,I'll drink it - if it's got a tune,I'll dance to it - if it's got a trigger, I'll shoot it - if it's got hair, I'll ride it.
Nite Ryder
Postby Treeview » Sun Feb 05, 2012 3:31 pm
Thanks NR,
You confirmed what I've found out. Time will tell if it puts out enough heat for my camper. I've been trying to find out what the btu output is for this one
When the time comes I'll install low oxygen, CO and fire alarms.
Treeview
Images: 30
Postby Martiangod » Sun Feb 05, 2012 5:23 pm
Made in France
900 watts, in europe
likely around 3000 btu, should heat a 14 ft 8 wide trailer.
They where optional equipment in 60's and early 70's airstreams
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby Treeview » Sun Feb 05, 2012 8:41 pm
Martian God,
That helps a lot. It should work fine in here:
http://stonerradiator.com/images/dsc00667.jpg
once I get the voids in the aluminum structure foamed and the ceiling/walls insulated.
Treeview
Images: 30
