How's it hanging? . . . your propane line, I mean.
Postby Big Dave » Thu Mar 15, 2012 4:02 pm
What's the best way to run the pipe under the trailer? I saw someone on an Airstream forum who said they just tack welded the black iron pipe to the frame, wouldn't that compromise the pipe?
Big Dave
Re: How's it hanging? . . . your propane line, I mean.
Postby Wanna Be » Thu Mar 15, 2012 4:31 pm
It would depened on the skill of the welder.
I have welded gas pipe before, BUT it was 6" in diameter and XXX strength, (XXX is aproxamatily 3/8" thick walled).
Very high pressure, and X-ray tested before use.
On a TD or TTT I can not recomend it's usage as the vibration would shorten the life expentcentcy of said pipeline.
Just my $0.02 cents worth from past experiences, YMMV !
Stay safe, and have fun !!!
Wanna Be
Lynn
This nation will remain the land of the free only so long as it is the home of the brave.
~Elmer Davis
"Well, if you can't believe what you read in a comic book, what can you believe?" ~ Bullwinkle J. Moose
Also I am a professional spelling butcher.. I don't carry a dictionary and my spell check is broke!!
Wanna Be
Postby Shadow Catcher » Thu Mar 15, 2012 6:42 pm
I am removing the 1/2" black Iron pipe and replacing it with 3/8 copper and will drill holes through the frame using grommets or sleeves to separate the copper from the aluminum frame. Currently the black iron is hung with stainless steel insulated straps and where it passes under the axle is the lowest point just waiting for a rock.
85694
Postby Martiangod » Fri Mar 16, 2012 8:07 am
Banded straps work great, just wrap in rubber to insulate
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby bobhenry » Fri Mar 16, 2012 8:29 am
My choice ( and they are cheap )
Images: 2614
