what type of line to use to run propane
Re: what type of line to use to run propane
Postby Sevo » Thu Mar 29, 2012 2:19 pm
kartvines wrote:After a quick internet search her is one link: http://gashosesandregulators.com/lowpressurehoses.html come to think of it mine may have also been 6 footers not sure, being it has been awhile
:applause: you are a google master! I couldn't find the things to save my life, I have been searching all morning!. Thank you so much for the link and the help
I am assuming I would want to buy the 5 PSI max hose?
Chris L.
http://www.NAFEX.net
The North American Falconers Exchange
Sevo
Postby Shadow Catcher » Sat Apr 07, 2012 6:53 am
I just went through this exercise and dumped the 1/2 black iron and installed 3/copper from tongue to three way branch under the trailer and up to the gas point, cook top and water heater. The only hose is from regulator to POL fitting at the tongue.
Copper is acceptable under RVIA standards.
Images: 200
Postby Sevo » Sat Apr 07, 2012 8:09 am
Shadow Catcher wrote:I just went through this exercise and dumped the 1/2 black iron and installed 3/copper from tongue to three way branch under the trailer and up to the gas point, cook top and water heater. The only hose is from regulator to POL fitting at the tongue.
Is 3 the size of the copper you used? What is the best size copper tubing to use in these?
Chris L.
Sevo
