Bringing propane into the galley
Postby DudKC » Mon Jul 30, 2012 10:17 pm
I have a question about running propane pipe into the galley. I currently have the same 1/2 inch pipe (as the pic below I took from the how's it hanging thread) running under the camper, from front to back, through holes in the frame. We were planning on using some flex pipe to go from the end of the iron pipe through the floor and up to the stove. However, we were told recently that "they" don't like flex pipe on the outside and that we need to run hard pipe up through the floor. I noticed the picture below and thought I would ask if that is the best way to do it, or if anyone knows if the DOT would have a conniption if we did it the way we were initially thinking.
I perused this subforum for a while and haven't come across the answer to my question so I thought I would start a new thread for a question that has probably been answered a hundred times in the past. Thanks for your help!
Dustin
View my build thread here:
http://www.tnttt.com/viewtopic.php?f=50&t=42426
DudKC
Images: 100
Re: Bringing propane into the galley
Postby CliffinGA » Mon Jul 30, 2012 10:38 pm
Dustin call your DOT and check with them, every state is different, heck in some cases even the ciunty's are.
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby bobhenry » Tue Jul 31, 2012 6:15 am
When I ran mine in the chuchwagon I ran 1/2" black pipe from the tank's regulator hose to and then up thur the floor THEN ran the flexpipe to the stove. The black pipe will take the road vibration and rock strikes but I wouldn't have the same faith in the thinner flex line. Once INSIDE the body where it is protected it should be fine. After all it was good enough for my house :D
9000 Club
9000 Club
Images: 2314
Postby DudKC » Tue Jul 31, 2012 7:07 am
Thanks, guys. I'll call our DOT and see if they can offer any advice on it. The last time I called them they weren't very helpful. If they don't give me an answer I'll just try to run the iron pipe up through the floor just to be safe.
Dustin
DudKC
Images: 100
