Need help connecting hand pump faucet to water tank
Postby E U G » Fri Aug 31, 2012 3:18 pm
Just bought my tiny trailer a few days ago and got my water tank delivered today. I'm wondering how to hook up the tank up to my faucet. My trailer has a built-in sink with a hand pump faucet. Underneath the sink, there is a clear tube hanging from the faucet, but I don't know how to hook this up to the water tank. The water tank has a spigot and an air hole. This is the tank I bought on Amazon:
http://www.amazon.com/gp/product/B001QC ... 01_s03_i00
I posted this question in one of my other threads and someone told me there should be a fitting on the tank. Am I supposed to buy a water tank that already has the fitting or can I buy the fitting separately somewhere? I asked at Home Depot and Fisherman's (outdoors store here in the NW) and they didn't know what I was talking about.
I'm leaving tomorrow for my first trip in this trailer so a quick answer would be much appreciated! :thumbsup:
Thanks!
E U G
Re: Need help connecting hand pump faucet to water tank
Postby len19070 » Fri Aug 31, 2012 6:06 pm
If you have a hand pump with a clear line coming out of the bottom I would first put the end of the clear line in a bucket/pitcher or something to hold water and pump the pump handle.
If water comes out then its easy.
Just stick the clear tube through the air inlet on the tank so it reaches the bottom, crack the water fill for air and your done!
Happy Trails
Len
len19070
Images: 24
Postby E U G » Fri Aug 31, 2012 11:51 pm
len19070 wrote:If you have a hand pump with a clear line coming out of the bottom I would first put the end of the clear line in a bucket/pitcher or something to hold water and pump the pump handle.
Happy Trails
Len
Thanks! Didn't know it was that simple, figured it needed a fitting of some kind. My clear pipe was too big for the air inlet so I just made the hole bigger with some tools. Do I need to crack the water fill though if I'm using a pump? My problem is I need to lay the tank down on its side which means water would be leaking from one of the two holes. It works fine now but I only tested it with a few pumps.
E U G
Postby Dale M. » Sat Sep 01, 2012 8:25 am
Actually you may have caused yourself some grief trying to connect up to that particular water container.... Its actually design is to just replace a bucket for water storage and transport ..... A true water tank for "RV" use is quite a bit difference in design.....
Any way.... Some of these containers have a threaded insert in fill cap so you can add a spigot to container to dispense water when its set on a table if this is so it may be place where you could add a barbed nipple to connect hose to... Simplest option may be put long hose on pump and simply set container on ground and draw from it... When traveling fill it up and cap it off and carry it along.....
You may even find some sort of "add on" bulkhead fitting for RV use that will allow you to put a hole in container in a place that will be convenient to connect a hose to...
Only limits are where/how you plan to place container, and how you can adapt a connection to container....
Dale
Dale M.
Images: 18
Postby slowcowboy » Sat Sep 01, 2012 8:39 am
I have went though 4 rv hand pumps and I hate to say they ether leak or I can't get them to pressure up and draw water out the facet!
on the 2 teardrop I am building for angie and me. I am going to put a wally world blue jug over the sink and skip the holding tank head aches and the rocket manual pumps totaly.
let gravity and pure simple do the trick and just drain the water from the blue jug set over the sink straight to the teardrops sink!!!!!!!!!!!!!
most the time I don't even use my fresh water holding tank.
on my current teardrop its way to easy to grab a gallon milk jug out of the suv or a normal one of them there water bottles like you buy bottled water in and pour it into my sink or my tea kettle for heating water to do dishes and forget the dang fresh water holding tank and its hastles and the rocket pump not working!!!!!!!!!!!!!
next teardrop is going to be a blue walmart water jug and gravity flow for my 2 teardrop!
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
6000 Club
6000 Club
Images: 166
