Good sale.
Good sale.
Postby jeff0520 » Fri Jan 25, 2013 8:03 pm
My local Tractor Supply store has this product: http://www.protanksupply.com/camping-propane-heaters_detail.asp?ID=7003 on sale for $90.00. WAY cheaper than this link I got in another thread. If that's the way you want to go for heat, it appears to be a good oppertunity. http://www.tractorsupply.com/mr-heater-reg-mh9bx-portable-buddy-heater-red-1000306
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Re: Good sale.
Postby Wimperdink » Sat Jan 26, 2013 3:57 am
You need a fan with this. I used mine in my tear and the rising heat warmed the ceiling up uncomfortably warm. A small fan redistributes the heat better. Also this is really overkill for a teardrop. It warms it up fast on low so you are back up in a few min to kill the heat. I had better luck with a small ceramic heater with a thermostat so I didn't have to keep getting up to turn it on and off. These are good little heaters for lil old standies though.
Wimperdink
Images: 33
Users browsing this forum: Majestic-12 [Bot] and 1 guest
