12v Water Pump Location
Postby Strop » Tue Sep 23, 2014 6:10 am
In all but 1 build I have seen the water pump is located in the galley.
Is there any reason the could not be mounted under the trailer? Especially if you are having a water tank under the trailer.
Thanks
Laurie
Strop
Images: 10
Re: 12v Water Pump Location
Postby SLUG36 » Tue Sep 23, 2014 7:56 am
my understanding on water pumps is that they work better pushing water than pulling water. being closer to the water source may be a better location.
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Postby MtnDon » Tue Sep 23, 2014 8:25 am
Personal observation is that water pumps work better when mounted lower. They prime easier, are quieter and deliver better flow. If it's a shurflo you are thinking of you can DL all the specs from Shurflos website. There is a maximum "head" given.
MtnDon
Images: 24
Postby Redneck Teepee » Tue Sep 23, 2014 10:05 am
Yes, always close to the tank as possible, and gravity flow if possible to the inlet side.
Redneck Teepee
Images: 21
Postby Strop » Wed Sep 24, 2014 5:30 am
Thank you. What you find in the planning stage is that there are compromises everywhere and making decisions of what's in and out.
I can get it close but no gravity feed unless tank is full.
I now have to figure out if I can get it to fit between the flood and axle.
Thanks
Laurie
Strop
Images: 10
