Is garden hose possible?
Postby MyYota85 » Fri Jan 09, 2015 8:01 pm
My goal/question is can I use 50ft garden hose and a bunch of fittings? I will mount tank under trailer and plumb using "garden hose" to sink and a shower. We will NOT be drinking this water as we have a 2 gallon jug of bottle water. Any help or experience would be greatly appreciated, thanks in advance..
MyYota85
Re: Is garden hose possible?
Postby felixx » Fri Jan 09, 2015 8:11 pm
Use a good one so it doesnt split in frosty weathers
felixx
Images: 22
Postby Shadow Catcher » Fri Jan 09, 2015 8:17 pm
Use the hose meant for RV water use, usually white.
Mine is plumbed with PEX.
Images: 193
Postby dales133 » Fri Jan 09, 2015 8:26 pm
That reinforced garden hose works fine for that sort of thing
dales133
Postby MyYota85 » Fri Jan 09, 2015 8:38 pm
We live in New Orleans so freeze is not an issue, the white pex style seems pretty expensive.
MyYota85
Postby Dale M. » Sat Jan 10, 2015 9:20 am
The better the quality the material (expensive) the less you have to deal with failure over time, cutting build cost is not always a money saver a year or two down the road...
Dale
Dale M.
Images: 18
Postby pmowers » Sat Jan 10, 2015 10:08 am
MyYota85 wrote:We live in New Orleans so freeze is not an issue, the white pex style seems pretty expensive.
True, but it is cheaper than being treated for lead poisoning, among the other nasties which leach from regular garden hose over time. Fill a garden hose with water, let it set awhile, then smell/taste the water.
I would recommend that whatever you use, it is NSF or food-grade. You can buy reinforced Tygon hose at the big box stores, and then use the proper fittings to connect. PEX is also a definite winner.
Growing old is mandatory, growing up is optional.
Build log:http://www.tnttt.com/viewtopic.php?f=42&t=51193
pmowers
Images: 43
Postby tlsallada » Sat Jan 10, 2015 11:24 am
Who know what nasties live in the materials used in the making of garden hose made in China. I've been camping for several decades in a combination of pop ups, motor homes or travel trailers and if memory serves me, I've used the same white RV hose all those years. Even though you may not be drinking water flowing thru that garden hose, I'd stick with the purpose built, white, RV hose.
Nowadays you can buy it from big box stores like Walmart or get it on line at a reasonable cost.
tlsallada
Images: 10
Postby MyYota85 » Sat Jan 10, 2015 4:58 pm
Sounds good guys, the few extra dollars saved will be worth it in the long run vs going to the doc for some type of disease.
Is it possible to literally use the pex from tank to shower? Then for drains I'll use pvc to gray tank?
MyYota85
Postby 48Rob » Sun Jan 11, 2015 8:39 am
Yes, and yes! :thumbsup:
Rob
Visit Rob's World Web Page!
48Rob
Postby len19070 » Sun Jan 11, 2015 10:19 am
Going a step further and talking about "ingesting Nasty's". I wouldn't ingest or cook with any water that has sat in a Potable water tank.
Thats why I don't have a Potable water tank.
This and Gravity work just fine.
Happy Trails
Len
len19070
Images: 24
Postby Socal Tom » Mon Mar 02, 2015 7:50 pm
I so the same as Len, I use the bottled water for cooking and drinking, but I always put fresh water in the tank and try and keep it clean enough to drink. If I do need it I want it to be safe, and I feel better better about cleaning with it.
Socal Tom
Images: 9
Postby Socal Tom » Mon Mar 02, 2015 7:51 pm
MyYota85 wrote:My goal/question is can I use 50ft garden hose and a bunch of fittings? I will mount tank under trailer and plumb using "garden hose" to sink and a shower. We will NOT be drinking this water as we have a 2 gallon jug of bottle water. Any help or experience would be greatly appreciated, thanks in advance..
I used tygon style clear hose sold at Home Depot. It costs a little more but they have the fittings too.
Socal Tom
Images: 9
