Tongue Boxes that fit a standard 20lb Propane tank
Postby wyrdone » Tue Jun 16, 2015 9:49 am
I'm having a doozey of a time finding a tongue box that will fit a 20lb propane tank.
Typically 12" in diameter and 18" tall. (I'd like a little wiggle room though.)
So anyone know of any that would fit? (Preferably Aluminum diamond plate but I'd consider any)
wyrdone
Re: Tongue Boxes that fit a standard 20lb Propane tank
Postby Verna » Tue Jun 16, 2015 10:46 am
Check Amazon for the trapezoid shaped ones that are 22" tall. You'd have to cut ventilation holes in them. Do a search on tongue boxes on Amazon.
Verna
Indianapolis, IN
Verna
Images: 49
Postby bobhenry » Tue Jun 16, 2015 11:14 am
Verna wrote:Check Amazon for the trapezoid shaped ones that are 22" tall. You'd have to cut ventilation holes in them. Do a search on tongue boxes on Amazon.
Well 21 1/2" tall anyway :D
http://www.amazon.com/Tradesman-21-Inch-Aluminum-Trailer-Diamond/dp/B001SF0S80/ref=sr_1_11?ie=UTF8&qid=1434471127&sr=8-11&keywords=trailer+tongue+box
9000 Club
9000 Club
Images: 2295
Postby bobhenry » Tue Jun 16, 2015 11:21 am
I would suggest a die grinder or metal cutting blade in a circular saw and make several slots in the underside of the box.
Since propane is heavier than air it settles. It will do little good to place vents high in the sides.
9000 Club
9000 Club
Images: 2295
Postby zroadhouse » Wed Jul 01, 2015 1:14 pm
I bought a Dee Zee DZ91717 for my build. It fits a 20lb tank no problem. I will be cutting holes in the bottom to allow propane and water to drain out. I'll also be adding vents on the side/top to vent the battery which will also be going in the box.
http://www.amazon.com/Dee-Zee-DZ91716-Triangle-Trailer/dp/B000VUE5HS
(Select the large one)
zroadhouse
Images: 103
Postby wyrdone » Sun Jul 26, 2015 11:38 pm
Ended up getting: UWS TVB-34. Which will fit two tanks if I want it to. (Or one and chock blocks, etc.)
http://www.amazon.com/gp/product/B000MK ... ge_o01_s00
wyrdone
