Tank level indicator
Postby lrrowe » Thu Feb 11, 2016 11:56 am
Too bad this item is not cheaper. It might have merit.
http://www.pplmotorhomes.com/parts/lp-g ... k-02-11-16
Bob
lrrowe
Images: 439
Re: Tank level indicator
Postby H.A. » Fri Feb 12, 2016 1:13 am
Interesting,
Wonder if it could work on tank other than propane...?
H.A.
Postby noseoil » Fri Feb 12, 2016 7:40 am
After this week & a phone problem, I'm wondering how long it would take to suck the phone battery dry (updates every 5 seconds).
137905
noseoil
Images: 99
Postby Redneck Teepee » Fri Feb 12, 2016 10:25 am
H.A. wrote:Interesting,
It should as long as its the same density of the liquid propane. But the manufacturer would be the one to ask.
Redneck Teepee
Images: 21
Postby Shadow Catcher » Fri Feb 12, 2016 11:31 am
The other solution that requires no monitoring is a translucent propane tank http://www.hexagonragasco.com/products/composite-lpg-cylinders
We have one from a company that did not follow DOT standards to their satisfaction and who they shut down. it is coming up on hydro re-certification shortly and there were never any failures of the actual tanks so intend to keep it. Having bucked up against government standards in the inspection work I did my skepticism that they just pissed off some some inspector...
The Ragagaso tanks meet specs and are less weight and will not rust and being able to see exactly how much you have and are getting when you fill up.
100408
Images: 193
Postby lrrowe » Tue Feb 23, 2016 9:04 pm
Another gadget for propane level detection.
Bob
lrrowe
Images: 439
