Propane stove for high altitude
Postby gene so » Sun Jul 09, 2017 11:04 am
Hello,
I am building a teardrop style trailer for hauling behind my 4 x 4 to be used both at civilized campgrounds and deep in the wilderness, The living space will be about 200 cu . Ft. I am seeking a propane space heater that will keep the cabin warm in inclement weather. From Minnesota, the cabin is being insulated adequately now. We are retired to 6,500 feet and I realize some propane units simply do not work efficiently this high. I also have found out some do not have a thermostat. With the insulation in winter, I am sure I will want to be adjusting the furnace for a long, safe winters' sleep; that is safe and comfortable.
I'd appreciate any insight so that I purchase only one type pf heater that is correct for the long term.
Thanks, in advance,
Gene So
gene so
Re: Propane stove for high altitude
Postby Jscwerve » Fri Jul 14, 2017 1:06 pm
I live at around 5500 feet. I've never had a problem with a propane appliance or tool.
I camp regularly at 9-11k feet and still have never really had any issues. Efficiency loss, yes, but not functional problems.
Jscwerve
Postby MtnDon » Fri Jul 14, 2017 5:17 pm
Ask the manufacturer if the appliance has an elevation limit. Many do. Many have replaceable orifices that reduces the amount of propane flow, but many do not. There are 2 things that can happen; carbon build up which may mean extra clean up and production of CO. Calculate the BTU efficiency loss to be about equal to a 3% reduction for every 1000 feet.
MtnDon
Images: 24
Postby John61CT » Fri Jul 14, 2017 5:47 pm
propex hs2211, ask at the Westy forum about altitude issues
John61CT
