Both hose and fitting are 1 1/4”. It’s the fitting and hose I bought for filling my water tank in the cargo trailer. I can’t get this hose onto the fitting, any suggestions? Tricks?
rainjer wrote:Put the end of the hose in boiling water to soften up a little.
Jeremy
Jeremy
GTS225 wrote:Hmmmm. We know it can't handle as little as 212*F. You might try a little Vaseline on the inside of the hose, then apply judicious force and attempt to screw the fitting into the hose.
Roger
pchast wrote:did you try to gently warm it with a hair dryer or
heat gun on low/warm.....
