#1
Re: #1
Postby ghcoe » Thu Dec 28, 2017 6:01 pm
Just realized I never posted up the maiden voyage and fall crawl meet up on this thread. So here it is. https://www.youtube.com/watch?v=XoaZZwLwcSc
George.
ghcoe
Re: #1
Postby Ned B » Tue Jan 02, 2018 2:28 pm
+1 subscriber
Ned B
Re: #1
Postby ghcoe » Tue Jan 02, 2018 5:41 pm
Ned B wrote:+1 subscriber
Thanks!
George.
ghcoe
Re: #1
Postby ghcoe » Wed Feb 28, 2018 9:19 pm
Added notes to first post viewtopic.php?f=55&t=54099 .
George.
ghcoe
Re: #1
Postby zzzizxz » Sat Mar 23, 2019 8:49 am
ghcoe wrote:Got the other roof piece kerfed today.
The first piece is glued and dry.
My GS ran out of pressure so I had to switch over to GG to finish gluing the two pieces together. I had just enough pressure to finish the outside perimeter with the GS
Hi @ghcoe, I know this is a really old thread, but I was wondering what you glued to laminate the two roof panels together. I'm going to be at this stage on my own build in a bit, and was wondering.
Did you apply GS (until you ran out) to the whole bottom sheet, or did you just spray it into the kerfs, or did you just go around the edges?
Also, if you did apply it to the whole sheet, how did you do that? Do you just spray some on and use a brush to spread it around Were you concerned with the GS expanding and buckling the two sheets in the middle, or does spreading it keep it from expanding so much?
Thank you!
zzzizxz
Images: 142
Re: #1
Postby ghcoe » Sat Mar 23, 2019 10:26 am
Thank you!
Well that does go back ways. I had to go back and read up some.
From what I remember I was not too concerned about the glue expansion at that point of the construction. My thinking was that the kerfs where going to absorb the extra glue in the expansion. I just basically poured the glue on. I did not really have much time to spread everything out evenly.
In thinking back on this, I think the Gorilla Glue would be a better choice for this kind of glue up since the expansion rate is much slower than Great Stuff and more controllable.
A suggestion would be to glue up your first panel to the walls. Then apply the GG to the first panel kerfed side. Then spray the GG with water with a spray bottle and then lay the top panel on and clamp into place. The water will activate the glue and cause it to expand more thus filling in some of the kerfs and creating a good panel bond.
Another suggestion, if your are still concerned about panel separation, is to use some 2"x2" inside and outside to act as a clamp. Place a 2"x2" on top that spans across the walls and then screw it into a 2"x2" that you have cut to fit between the wall inside. This would hold the curve in the correct position and keep the panels from separating as the glue dries. I think if I do another curved front build I would use this technique. Screw holes are easy to fill later. I think you would only need a screw in the center and one on each side for this technique.
Well, hope this helps you out, George. :thumbsup:
George.
ghcoe
Re: #1
Postby zzzizxz » Sat Mar 23, 2019 1:44 pm
[/quote]
Well, hope this helps you out, George. :thumbsup:[/quote]
That does help, thank you! I really like the 2x2 idea as well. I think I'll probably go that route when I get there.
Thanks!
David
zzzizxz
Images: 142
Re: #1
Postby ghcoe » Sun Sep 01, 2019 9:17 pm
Well after nearly 2 years I finally decided I needed to really finish #1.
I am dead in the water with #3 till I get caught up with my videos (see my Bug Out Trailers YouTube channel https://www.youtube.com/channel/UC3xVuH ... SiploqPyrw). At this rate I will probably not get anymore work done on it till next spring.
#2 is still a work in progress, but is usable at this point.
#1 needs some attention since I have not done anything to it since nearly completed in 2017.
You ask nearly completed? :thinking:
Well yes. I built it to a point where I could use it, but it really was not done. I still needed to put on the skirts that I had planned. Mostly this was just a cosmetic application so it was not a need to do till I got bored looking at it each day. I kept thinking I really need to finish this up so I don't have to look at it anymore. So here we go.... :thumbsup:
George.
ghcoe
Re: #1
Postby ghcoe » Sun Sep 01, 2019 9:26 pm
So here is #1 ready for some cosmetic surgery. Yes, she looks great, but we can make her look better by adding a skirt.
before skirts
20190825_103226 s.jpg (262.69 KiB) Viewed 4121 times
first we needed a pattern. This is easy to do with a piece of cardboard. I usually do not throw out big cardboard boxes for just such use. I also use cardboard to lay on when working on cars, trailers or anything else that requires me to sit or lay on the ground. Works great!
pattern
20190825_121004 s.jpg (293.58 KiB) Viewed 4121 times
Once I trace out the pattern onto the foam it is time to cut it out. I find that band saws work fantastic to cut out small pieces of foam. They make a real clean cut, almost as good as a hot wire, but a lot easier set up.
cutting the foam
20190830_085404 s.jpg (286.28 KiB) Viewed 4121 times
George.
ghcoe
Re: #1
Postby ghcoe » Sun Sep 01, 2019 9:34 pm
Once I cut the foam it is time to canvas. I had forgotten just how long canvasing small parts with lots of angles took.
canvasing
20190830_095842 s.jpg (248.46 KiB) Viewed 4120 times
with small parts you have to wait for each surface to dry completely before moving on to the next angle. Takes hours and hours of waiting.... Here the first surface is drying.
canvasing #2
20190830_104412 s.jpg (265.63 KiB) Viewed 4120 times
Here is a in process shot of gluing up another angle of the part. In this build up I used 50/50 TBII and water on the large surface and then switch to the edges and back side with full strength TBII.
canvasing #3
20190830_180931 s.jpg (312.07 KiB) Viewed 4120 times
George.
ghcoe
Re: #1
Postby ghcoe » Sun Sep 01, 2019 9:48 pm
Once the glue dries I cut the edges using a piece of flashing for a straight edge and a box cutter. The box cutter will only cut a shallow cut into the foam, but it makes a nice and clean cut in the canvas.
edging and box cutter
20190830_174714 s.jpg (302.34 KiB) Viewed 4114 times
Once I make the cut I peel back the excess canvas on itself as to not lift up on the canvas that I want to keep bonded to the foam.
removing excess canvas
20190830_174742 s.jpg (299.48 KiB) Viewed 4114 times
Once I get all the canvas work done I want to add attachment points to the skirt. In this case I want to attach the skirt to the 2"x2" cross members I installed under the floor. I marked where the 2"x2" would be located on the back side of the skirt. I then used a hot wire to cut out a 1 1/2" deep pocket to accept a 1"x2"x7" piece of lumber.
hot wire
20190901_100143 s.jpg (289.76 KiB) Viewed 4114 times
George.
ghcoe
Re: #1
Postby ghcoe » Sun Sep 01, 2019 10:15 pm
Now it is time to prep for glueing the 1"x2"x7" piece of lumber into the back of the skirt. I placed the 1"x2"x7" piece of lumber into the hole and then clamped them to a block of wood that was cut true to 90 degrees. I then used a square to verify 90 degrees from the sides. Since I placed the 1"x2"x7" pieces of lumber all the way down into the pockets I am not expecting to much, if any, hydraulic lift from the glue . I am going to use Great Stuff to glue them in with. The blocks of wood and clamps I used to hold the 1"x2"x7" pieces straight for glue up will also add a bit of weight to help with hydraulic lift too.
glue prep
20190901_101903 s.jpg (267.56 KiB) Viewed 4097 times
I then used Great Stuff to fill the pockets. This glues in the 1"x2"x7" supports.
Glue installed
20190901_114006 s.jpg (296.3 KiB) Viewed 4097 times
Once the Great Stuff dried I took off the support blocks and now I have my first skirts ready to install once I remove the excess glue. :thumbsup:
Ready to install
20190901_114205 s.jpg (283.23 KiB) Viewed 4097 times
George.
ghcoe
Re: #1
Postby pchast » Mon Sep 02, 2019 9:12 pm
What kind of wire are you using in the solder gun for a cutter?
How thick is it? I haven't found anything that won't bend when
heated yet.........
:thinking:
Thanks for the info.
pchast
Images: 97
Re: #1
Postby ghcoe » Tue Sep 03, 2019 6:41 am
pchast wrote:What kind of wire are you using in the solder gun for a cutter?
heated yet.........
:thinking:
I believe it is .030 flux core welding wire for all my hot wire needs.
George.
ghcoe
Re: #1
Postby pchast » Tue Sep 03, 2019 10:17 pm
Thanks, I'l try that. :D
pchast
Images: 97
