So I primed the foam with kilz let it dry
Painted the foam with tite bond 2 1to1 with water placed the canvas on the foam and then painted the canvas with tite bond 2 with water
Four days later the canvas peels off
What did I do wrong?
Ohhhh ok thanks!ghcoe wrote:Canvas will peel off of foam quite easily if you try. The idea is not to try. What seems to be a weak bond is actually all you need. The strength comes in shear not in lift.
Hmm oh well everything I read and watched said to prime the foam...... could a saved $20KennethW wrote:You don't paint the foam !!! You should have when over the foam with a wallpaper cutter(used to remove pall paper) then glued the canvas to the foam with lots of tite bond II. NO KILZ
Outoforder wrote:Hmm oh well everything I read and watched said to prime the foam...... could a saved $20KennethW wrote:You don't paint the foam !!! You should have when over the foam with a wallpaper cutter(used to remove pall paper) then glued the canvas to the foam with lots of tite bond II. NO KILZ
Sent from my SM-G965U using Tapatalk
