Can/should you cut holes after PMF-ing?
Postby Fractangle » Thu Sep 16, 2021 1:30 pm
From what I've seen on here, the general process is to cut holes (doors, roof vent, etc) in the foam body before applying PMF. However, I'm trying to plan my build to be incremental - I want to be able to add a skylight or a 2nd door or whatnot later. Could I just cut a hole in already-PMFed foam, apply a strip of PMF around the cut edges, and not suffer the wrath of the waterproofing and/or delamination gods?
Fractangle
Re: Can/should you cut holes after PMF-ing?
Postby linuxmanxxx » Thu Sep 16, 2021 2:32 pm
Holes for windows and doors need framing for attachment and strength. Water inside is the enemy more than anything and the cloth coming loose and peeling is more a strength issue than leaking so it would be best to wrap over the holes but at least do strips.
You get a lot of strength in a completed closed structure but it's still foam and cloth.
Sent from my Pixel 4a (5G) using Tapatalk
linuxmanxxx
Images: 10
Postby ghcoe » Thu Sep 16, 2021 5:23 pm
I have made cut outs on walls that were already PMF'd on one side and both sides. Here is a door I cut out recently.
#1
20210821_164728_HDR s.jpg (401.83 KiB) Viewed 625 times
#2
20210821_164734 s.jpg (339.83 KiB) Viewed 625 times
#3
20210823_122607 s.jpg (354.78 KiB) Viewed 625 times
Just make sure you cut out the pattern correctly or you may have some issues.
George.
ghcoe
Postby Fractangle » Fri Sep 17, 2021 9:26 pm
Interesting - thank you for the pictures! Have you had any problems with the cut edges of the PMF wanting to shrink away from the cut edge of the foam?
Fractangle
Postby ghcoe » Sat Sep 18, 2021 11:49 am
Fractangle wrote:Interesting - thank you for the pictures! Have you had any problems with the cut edges of the PMF wanting to shrink away from the cut edge of the foam?
No. Most of the shrinking is from the initial lay up.
George.
ghcoe
