Materials Poll
Re: Materials Poll
Postby TheOtherSean » Sat Apr 23, 2016 9:52 pm
George,
You didn't use your three G's of foamie construction! Are you new materials choices working better than your three G's?
TheOtherSean
Images: 111
Re: Materials Poll
Postby ghcoe » Sat Apr 23, 2016 11:09 pm
TheOtherSean wrote:George,
Well caulking is working better for me right now. There is still a lot of logic in the three G's for others. I just find using one product for most applications is more convenient. The caulking is really working great for all my needs and seems to be as good a bond if not better than the other products. What I like best is that it does not foam, which can lift or push things around, but it is still able to fill voids and irregular surfaces in the foam for good bonding. Plus, it is easier to store, and clean up. It bonds dissimilar materials together well and is more economical.
George.
ghcoe
Re: Materials Poll
Postby GPW » Mon Apr 25, 2016 6:40 am
QUOTE: “ but it is still able to fill voids and irregular surfaces in the foam for good bonding “ ... That’s actually pretty cool !!! ... Adhesive and filler in one ... :thumbsup: 8)
Foamie construction s seldom “perfect" and a little convenient filler is much appreciated ... :D :beer:
Re: Materials Poll
Postby joyofweaving » Thu Apr 27, 2017 7:14 pm
ghcoe wrote:Type of foam: Extruded Styrofoam
Adhesive, foam to foam: ALEX PLUS latex caulk
Adhesive, foam to wood: ALEX PLUS latex caulk
Type of fabric covering for foam: 10oz. Canvas
Adhesive, fabric covering to foam: Tightbond II
Type of fabric covering for joints: Canvas
Adhesive, joints: ALEX PLUS latex caulk
Fabric weave filler material:Latex
Type of exterior paint: Latex
Type of interior paint:Latex
Thanks for asking this question. I was going to ask what less expensive alternatives there are to the "Three Gs" which are suitable and this answered it. We already have plenty of oops paint that I bought years ago and finally have a use for and Alex Plus is hella cheaper than GG and GS. :applause:
We have to work on a shoestring budget. This really helps.
You have to be warped to weave.
joyofweaving
Re: Materials Poll
Postby ghcoe » Thu Apr 27, 2017 9:11 pm
It is cheaper, but it does take a longer time to set up and fully cure.
George.
ghcoe
Re: Materials Poll
Postby Redneck Packrat » Tue Jun 27, 2017 9:20 am
GH: How long did it take your Alex Plus to cure enough to remove clamps, wood-to-foam? Overnight?
Bill
Texas Gulf coast, near Corpus
Working on this, started 5/2017: http://www.tnttt.com/viewtopic.php?t=68614
Some days you're the bug, some days you're the windshield :?
Redneck Packrat
Re: Materials Poll
Postby ghcoe » Tue Jun 27, 2017 9:46 pm
Redneck Packrat wrote:GH: How long did it take your Alex Plus to cure enough to remove clamps, wood-to-foam? Overnight?
It will usually dry to a point where you can handle it in a few hours. I glued two 6"x6" pieces of foam together and I was not able to separate them by hand the next day. I cut through the piece and it had cured about a inch in around the edges. I then waited a week and cut through the pieces again. It was fully cured edge to edge at that point. Granted it was only two 6"x3" pieces at that time. I could not separate the pieces by hand or by putting my weight on one side while resting the other side on a counter edge.
George.
ghcoe
