by Bob Hammond » Sun Jul 10, 2016 10:49 am
The glueup went easily.
First, I placed two old 75" steel bedrails in the workmates (two workmates are much handier than one!) and carefully leveled them with a digital level. Then i laid the straightest cedar 2x4s across them, and then wrapped them in plastic to prevent gluing the deck frame to the 2x4s. i then dry-fitted the crossmembers into the mortises of one rail, and then for the other side a daughter helped to spread glue, insert the tenons into the mortises, and then measure the diagonals to ensure squareness. After the first rail was glued up, the second rail went easily also. A check with my digital level shows that one crossmember is 0.1d off-level, but the rest are level. After two big thunderstorms in two days, the frame is still straight, square, and level.
As it is now, the cedar 2x2 grid weighs ~50lbs. Now I'm thinking about routing a ledge around the spaces of the frame to fit the the 1" rigid insulation flush to the surface of the 2x2s. After that, i'll probably skin the top with a quality underlayment and then canvas the entire frame.
I can't do much more work until the trailer chassis comes back from the shop. I had decided that the chassis might need some reinforcement to the tongue, and so I took it to a professional builder. He really liked my homebrew Harley strut/spring suspension, and estimated that after the modifications it would easily carry 1500lbs. Aside from adding the reinforcements, he also offered to weld all of the bolted joints and the jack for $240, labor and materials.
- Attachments
- IMG_20160710_112840.jpg (232.58 KiB) Viewed 903 times
Curator
Museum of Unfinished Projects
