Re: Biggest foamies?
Posted:
Thu Jan 21, 2021 11:19 am
by rowerwet
Mine is 6x13 with a flat plywood roof, supported by 1x3 spars on edge. I keep the tear parked nose or tail high for drainage. I plan on creating a standby out of it someday, with a bowed roof to not have to think about draining
Posted:
Thu Jan 21, 2021 11:43 am
by Socal Tom
I would think that if you sandwich a wood "stringer"( like they do with surfboards) you will probably be ok.
https://youtu.be/qNHWbRV432s
Posted:
Fri Jan 22, 2021 12:05 pm
by Terra6
Trick question.
They're building foamie houses and buildings.
If you include SIPS panels.
Basically, like any living thing, reinforcing structure frame required the bigger one builds.
Foam only seems 4x4x8 2 inch XPS is reasonable unsupported or unframed if that is what you're getting at.
Larger if skinned on both sides.
