OK, the old press is Gone ... Yippee !!! No more blocking the door ... So naturally I had to pull my Foamie inside where It now blocks the door ...
That and #13 is on the way bringing too much , much needed rain ...
Upon giving it more than a casual glance , I found my First problem ... Yep, you guessed it ... the Plywood ... grrrrrrrrr!!!!!! Got a small bubble past the fabric by my door (My Bad , I never finished the door seal
) ... where the fabric was it didn't bubble , where it was just painted it did ... I'm learning to Hate plywood... will drill a small hole , inject glue and clamp it flat .... then get to work on the door seal ...
And of course , now that I have it inside out of the Heat , the weather's gotten comfortably Cooler ...
[url][/url]
