Re: A more durable Foamie?
Posted: Wed Jan 25, 2017 12:28 am
ghcoe wrote:Every build technique is going to be a compromise. It just depends on what you want to compromise.
Always a compromise, the trick is to optimize! I'm happy to spend more money and time and add weight in the pursuit of greater durability. Within reason!
I'm not going to go bashing through tree limbs if I can avoid it. But I know I'm going to encounter some because my rig is taller than most that make it into the boonies. Heck I'm going to have solar on the roof so I need to be careful about what I run into. I figured that if I kept the solar in the center of the roof it wouldn't be too vulnerable.
I've done some more reading about Styrospray and encountered the issues mentioned about humidity. If it's too dry it just doesn't cure properly. I don't think it's for me, but if someone else wants to play with it, it might be very useful for some.
My comfort level keeps bringing me back to what I did before. The panels had solid wood edges, with a fiberglass layer over it that was very tough. No problem with branches. Or flying turkeys . Seems like any edge that just has foam underneath will be far more susceptible, no matter what the exterior is.
