Re: Thrifty Alternatives ..Building Foam Campers
Postby GPW » Wed Aug 05, 2020 4:32 am
TB2 or TB3 still works … :thumbsup:
Postby John61CT » Wed Aug 05, 2020 3:05 pm
As adhesive under, but for waterproofing, between the canvas and the outer paint?
John61CT
Postby linuxmanxxx » Wed Aug 05, 2020 4:22 pm
To attach canvas to foam and wood. 2 is very highly water resistant and 3 is waterproof so they naturally do both glue and seal.
Sent from my Pixel 3 using Tapatalk
linuxmanxxx
Images: 10
Postby Pmullen503 » Wed Aug 05, 2020 4:46 pm
The paint, typically latex, also adds to the waterproofing.
Pmullen503
Images: 67
Postby GPW » Thu Aug 06, 2020 5:43 am
It’s not the glue but the procedure … ;)
1. Attach canvas to CLEAN foam .
2. Add thin sizing coat to waterproof canvas fibers .
3. Paint the outside for weather and UV protection …
Postby Pmullen503 » Thu Aug 06, 2020 9:08 am
GPW wrote:It’s not the glue but the procedure … ;)
My *opinion* is it makes sense to apply the second (saturating) coat before the first (adhering) coat has fully dried. I've wondered if it really makes a difference on canvas. The thought is that any polymerizing glue/coating (as opposed to solvent based like lacquer) sticks better to the earlier coat if the earlier coat is not fully polymerized.
Pmullen503
Images: 67
Postby GPW » Fri Aug 07, 2020 4:14 am
PM , If the first coat holding canvas to foam is not dry , the sizing coat only rewets the underlying glue … I tried it …
Postby GPW » Sat Nov 07, 2020 8:36 am
And while surfing You Tube , I saw this and thought of “ Thrifty Alternatives” … :thumbsup: https://www.youtube.com/watch?v=sc6ZXR0 ... &index=126
Postby John61CT » Sat Nov 07, 2020 9:07 am
Nice! added to my wigwam / dome thread
http://tnttt.com/viewtopic.php?p=1243883#p1243883
John61CT
Postby ghcoe » Sat Nov 07, 2020 9:13 am
I have been approached to build a bicycle trailer. I was doing some research and saw that video. Pretty cool. I am not sure where I had saw it, but years ago I found a link to a 1930's teardrop build that used just a simple wood frame with a canvas covering. It was basically just a sleeper, but had a kitchen built into the floor that you covered up to make the sleeping platform. Small, but functionable. Only think I don't like about them is that they supply little to no insulation.
George.
ghcoe
Postby John61CT » Sat Nov 07, 2020 2:00 pm
Get the shape you want then spray closed cellPU foam from the inside
or pour from the outside
then shape to get an even thickness.
For snowy mountain living, 3-4" would be enough.
For more temperate, 1-2".
John61CT
Postby GPW » Sun Nov 08, 2020 4:47 am
I was kinda’ thinking of splitting Large Bamboo into uniform slats to make the ribs . Bamboo can easily be heat bent to retain the shape … :thinking: More like hoops for a Conestoga wagon … sorta ‘ .. Just another idea !!! :thinking:
Postby Douglas Knudson » Wed Nov 18, 2020 5:38 am
Wow, I just finished reading this loooong thread. Lot's of good ideas. Doug :beer:
2017 Jeep Sahara
2020 Homebuilt Foamie
Douglas Knudson
Images: 21
Postby GPW » Wed Nov 18, 2020 6:25 am
Well done DK !!! Now you know as much as we do !!! 8) :thumbsup: :beer:
Postby Douglas Knudson » Thu Nov 19, 2020 8:54 am
Hey GPW, I'd like to find more detailed drawings of a Willey Window. Do you have some? I private messaged you on FB. TIA Doug
2017 Jeep Sahara
Douglas Knudson
Images: 21
