Edit: Looks like the smaller images are automaticly sized down from my uploaded size. Guess we're all going to have to get used to clicking on images and then using the back button.
Well when I woke up yesterday it was raining pretty hard, so I chose not to go to the CAS (Cowboy Action Shoot). Went back to sleep and caught up on some much needed rest in preparation for today's build progress!!
Still working on the swivel coupler parts, I started right in with clamping the second clevis (U-Joint Yoke). Based on the experience with the first clevis sucking in when welded I used two of the .010 thk aluminum flashing shims per side this time.
Anybody see anything wrong with this picture? Me neither...at the time.
First root pass on each side.
(Sorry, some of these pics came out blurry.)
Almost there, both sides.
Fully welded.
Note the contour of the weld will support rounding over on the sander.
Welded the inside of the first clevis. Note the alignment/plug weld hole in the center of the hub.
After Clevis 2 had cooled down I started measuring to see how much it had pulled with the weld...something wasn't adding up.
Uh oh.
Doh, forgot to put the two 1/8 cap plates in to represent the bushing flanges. Here you see that the first clevis has shrunk to where only one of the 1/8 plates can be inserted with the flashing shims, and the second clevis won't accept any.
Oops.
Interesting to note that there were two of these 1/8 inch plates in there, plus two of the shims when I welded the first clevis, and now only one fits easily.
Well I surely was not going backwards, and was not going to start clevis 2 over. We briefly considered milling out the yoke ears, but I did not want to thin them this much, so the remedy will be to mill the sides of the U-Joint down to suit the clearance required for the bushing flanges and a small running allowance. Each end of the U-Joint will be slightly different to accommodate the different yoke sizes.
Moving on. Welded the inside of the second clevis.
Sanded the first clevis.
Made the little lock tab for the newly designed U-Joint removable pin retainer.
Here's another mock-up of the pintle shaft and related parts.
Checking the stack up of the bushing sleeve and bushings.
Put the big fixture washer and nut on the pintle shaft and checked the inside measurement of the pintle shaft shoulder-to-washer against the previous measurement (no pic). Things were too tight. Dave Z. had done a good job on the pintle shaft, but the thrust bearing surface of the thrust shoulder was a little rough and I would have liked a bigger radius where the shaft meets the thrust shoulder. So, even though the shoulder had ended up a little thinner than the plan (slight mental math error by Dave) I decided to take a skim cut off of the thrust shoulder instead of the sleeve. This would allow me to improve the finish of the thrust face, and at the same time increase the radius. I found a carbide cutter that had a chip out of it and sanded it to the radius I eyeballed would match the new cut to the old radius. Took a while to do this on the Bader...Carbide is really hard!
Can't really see the details, but this is a pic of me plunging the radius cutter along the face of the thrust shoulder in Karl's lathe, just until it kissed the OD of the shaft.
Took about .030 off leaving about a scant 3/32 radius. Hit the outside edge of the thrust shoulder with a flat file to deburr/chamfer, and checked the stack up fit directly.
Running thrust clearance is now about .025. This new pintle shaft is spot on the max dimension of 1.500 inch so the bushings won't go on until they are installed in the sleeve and reamed to size. Also, the forward bushing will need to be chamfered slightly on the ID to clear the larger radius on the shaft.
With that set it was now okay to weld the bushing sleeve into the little front xmbr. Pulled a couple of 1/4 inch scraps out of the bin and set the xmbr up to establish the required stick out, square axis and parallel faces.
Four good opposing tacks, then 1 inch arcs alternating in a star pattern. And the resulting welds.
Blocked the xmbr up off of the sleeve and shimmed the xmbr end caps up.
Tacked the cap plate on.
Shim left a reveal that will be left unwelded for now.
Then welded the three sides of both cap plates, leaving the reveals unwelded.
Mock-up the xmbr to one of the tongue rails. Now you can see that the reveal provides a weld prep where all three pieces will be welded at once when the xmbr is attached to the tongue.
I can weld this.
Did the rock slider cap plates in a similar fashion. Here they are welded on three sides.
I was going to leave these parts at that, nice welds standing proud, but Karl says, "Aren't you gonna sand them?". Me, "No, it's a trailer, not jewelry." Karl, "Oh, I always sand everything. You could catch a rock on that edge." (Chiding me, I know.) "You're pulling my leg, com' on," I said while looking at the nicely sanded radii I had so proudly done on the main frame rails, "I'm not gonna hold the frame up to the Bader when we weld it up." Karl, "Flap wheel." Damn, got me there, off to the Bader, and here they are all sanded up nice.
Wife worked on Saturday, so finished early to have a nice meal together at a small local pasta shop (
http://www.paulspastashop.com/index.htm, in the summer you can sit out on the deck overlooking the Thames River), sauteed shrimp, asparagus, mushrooms and herbs in a white wine/olive oil sauce over fresh linguini. Lots of garlic. Yum.
