GPW wrote:Ruff, had that been allowed to cure completely ( weeks ) ....
Yes, that was one of the first pieces I made, so at least a couple weeks.
gizmotron wrote:I'm just wondering if adding stringers, like wing spars, to the 2" Owens Corning Foam, glued with GG would add strength and stability to it or actually decrease the strength?
....The foam has break points at 16" and or at 24" running the long way down the foam. 2" wide 1/4 inch plywood stringers could be glued between those snap points to facilitate a stronger hold down technique. They would become embedded stringers, just like the foam plugs made by Clark.
rruff wrote:gizmotron wrote:Regarding your question about the hard points for solar panels, I've seen people just make a cut in the foam and glue an aluminum L in place, one leg straight down into the foam and the other nearly flush with the top. That way you have a glue joint on both sides of the embedded leg, and another under the one that lays on top. It's an alternative to using wood that might rot.
For your 1/4" plywood spars are you using marine ply?
GPW wrote:We used stringer and former (aircraft) construction with XPS over that ...
GPW wrote:The real question is .... How much strength and durability do you NEED ??? ...
gizmotron wrote:I want a super ultra-light.
I've read the data on the screwdriver puncture tests. I wonder how that relates to a tear test.
gizmotron wrote:So, I want rich man's fiberglass. Heck with poor man's anything. It will be lighter and stronger, issue settled. So somebody, and it might be you said that they found a cheaper outlet for the fiberglass and the resins. I need to find the glass and epoxy at a good price too. Was that ever discussed?
