Wolffarmer wrote:Do the u bolts go over the axle with out using force?
Will the u bolts go in the plates when not being put over the axle?
If they don't go into the plates how far off are they?
As we say in farm mechanics. "Don't use force. Get a bigger hammer"
Randy
Wolffarmer wrote:Is axle square? or is it slightly rectangle?
parnold wrote:The u-bolts are supposed to be a snug fit on the axle. The tolerances are just slightly off. Using a clamp will be a good solution, just be careful not to bugger up the threads with the clamp. I had problem with one of my u-bolts also.
Users browsing this forum: droid_ca and 15 guests
