RE: Other Things Made From Foam
Postby mezmo » Wed Jul 13, 2011 3:30 am
Hi All Foamlings,
I came across something that made me decide to start a thread about
anything made from foam - or foam used as a major component.
Just to help show its versatility and how it can be used for many things.
And to help reinforce the idea of foam as a legitimate construction
material when and if applied/used correctly...
Here's the link to the inspiration for this thread.
http://www.itechdiary.com/spira-three-w ... erial.html
Norm/mezmo
mezmo
Images: 194
Postby CliffinGA » Wed Jul 13, 2011 10:52 pm
That is seriously cool!! Makes you :thinking: maybe a foamie canoe or yak to go with your foamie tear?
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby tinksdad » Thu Jul 14, 2011 10:17 am
Plans! We don't need no stinking plans!!
But this guy is selling plans for D-I-Y foam kayaks. We build teardrops, I'm sure we can do it without buying plans. :thinking: And probably prettier as well.
http://cgi.ebay.com/KAYAK-PLANS-lightweight-foam-kayak-21-pounds-plans-DVD-/190517714262#vi-content
tinksdad
Images: 155
Postby Cliffmeister2000 » Thu Jul 14, 2011 10:37 am
If you are going to build a bunch of foam stuff, you will need a Foam Cutter
Or maybe you need a CNC foam cutter!
Here's a neat article on how to build a foam boat
Want to do fiberglass over foam?
This guy is building a home of foam
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby GPW » Thu Jul 14, 2011 12:47 pm
Cliff, although I built the jigsaw type foam cutter , the hot wire bow was actually used much more ... and you can do gravity cutting too ...
RE: Foam Dome House
Postby mezmo » Thu Jul 14, 2011 11:12 pm
Here's a link to a Japanese Co. that makes Foam domes for use as
housing:
http://www.i-domehouse.com/
It's still the same principal of foam as the core/shape maker and the
strength being in the "skins" [also in the shape too]. Good insulation
values are a bonus.
Wow, combining two Items of interest here: Domes and Foam.
Norm/mezmo
mezmo
Images: 194
Postby GPW » Fri Jul 15, 2011 5:38 am
Guess we should have let the Japanese develop Foamie trailers... They seem to have it all worked out ... ;)
Nice to see we're not alone in recognizing the properties of Foam ... :thumbsup:
Postby jhanlon » Mon Jul 18, 2011 6:15 pm
Foundation forms made of foam and offer serious R values for basements.
http://www.greenlightcustomhomes.com/icf-foundation/
john the Vanner
John the Vanner - now with 41 X 48 HF trailer
jhanlon
Postby 2old2tent » Tue Jul 19, 2011 7:40 am
jhanlon wrote:Foundation forms made of foam and offer serious R values for basements.
john the Vanner
We built our house using the ICF's. If I had it to do over again I would figure out a way to use more of it. :D All four exterior walls and two interior load bearing walls are foam. It is quiet and is easy to heat and cool. Our's is also a berm so half way underground as well.
Foam on!
Jack
2old2tent
Images: 41
Postby GPW » Tue Jul 19, 2011 8:58 am
Jack, you a slide player huh ??? 8)
Postby 2old2tent » Tue Jul 19, 2011 10:49 am
GPW wrote:Jack, you a slide player huh ??? 8)
It just looks that way, I'm just a strummer. I play that way because I don't have a right arm from the elbow down and that is the only way I can reach the strings. :lol:
Here is a pic that shows it better.
Jack
2old2tent
Images: 41
Postby GPW » Tue Jul 19, 2011 12:05 pm
Jack ... Most excellent you can do that ... :applause: From the small pic , I though you were playing slide ... My hat's off to you !!! 8)
