more paint questions
Postby rustytoolss » Fri Jun 30, 2017 11:31 am
Choosing paint for the exterior of my trailer. I want a gloss/high gloss paint for the body . Any cons with using high gloss enamel paint. Or would using 100% acrylic latex be a better plan. Ease of use is important, as is drying time and clean up.
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: more paint questions
Postby GPW » Fri Jun 30, 2017 12:11 pm
You may want to stick with the usual Latex Ext House Paint , although a good bit of “Enamels “ these days are also Latex… Just remember common house paint works fine … really Anything that wouldn’t melt the foam …
And since it doesn’t take much , you might want to get the “better” paint , for durability and ease of application …
Postby QueticoBill » Fri Jun 30, 2017 1:04 pm
Generally, the higher the gloss, the more imperfections will show. I'd love a high gloss but think a semi-gloss is enough more forgiving that it's a worthy compromise. As far as water or mineral spirits, I'm a late convert to latex. And disposable brushes and rollers to some degree. (I do love shellac for interior trim and wood paneling.)
QB
QueticoBill
Images: 22
Postby linuxmanxxx » Fri Jun 30, 2017 1:05 pm
The water enamels dry considerably faster than latex.
Sent from my Nexus 6P using Tapatalk
linuxmanxxx
Images: 10
Postby rustytoolss » Fri Jun 30, 2017 9:38 pm
GPW wrote:You may want to stick with the usual Latex Ext House Paint , although a good bit of “Enamels “ these days are also Latex… Just remember common house paint works fine … really Anything that wouldn’t melt the foam …
MELT FOAM that got my attention :shock: :cry: Give me some info on what to stay away from ! :worship: How would I know what brand/ type of paint will melt foam ???? :NC
Hint :: brand ? paint name ? what ever you know that is a good choice. :thumbsup:
I was planning to buy paint and gripper real soon. There are some deals through 7-5-17
rustytoolss
Postby GPW » Sat Jul 01, 2017 5:42 am
Rusty , All paint is 3 parts …. the Pigment , which gives it color , the Binder, which is the “glue” that holds it all together , and the Solvent , which dilutes it to a workable consistancy , and also cleans it up… The solvents in the “old days” were rather nasty chemicals that would easily melt bare foam … ( including gasoline) …
Today’s water based (Acrylic Latex) paints are pretty Foam safe ,the solvent is Water, but it never hurt to do a little “TEST” first on a piece of scrap foam …
We “Foamlings” who have no rules ,only have two “suggestions” … Test Everything First…then tell us all about it … ;)
