Shoebone wrote:Thanks for all of your constructive comments, I'm glad I asked the question. My foam is XPS so that's good, more trailer bracing and crush blocking are two things I hadn't considered and yet they are so obvious now you mention them, this forum is the best, Thanks again
ghcoe wrote:A sandwiched floor is a strong structure and well insulated, but keep in mind that you will be adding 2 1/2 inches of height to the overall structure and almost 60lbs to the overall weight than if you just go with a single sheet of OSB/ply.
amandacreiglow wrote:ghcoe wrote:A sandwiched floor is a strong structure and well insulated, but keep in mind that you will be adding 2 1/2 inches of height to the overall structure and almost 60lbs to the overall weight than if you just go with a single sheet of OSB/ply.
Agreed on the height addition -- I actually wanted this, for height/hatch/door reasons, but yeah, it's a concern if you don't want that height. Don't think it adds that much to the weight, though. The floor is 50-60lbs with 1/4 ply on top and bottom, yes, but without the sandwich method, most people go with 1/2 ply, which is nearly as heavy. You're really only looking at an addition of 10-15 pounds, I would think.
John61CT wrote:I just hate wood for flooring, too heavy, ends up wet and stinky.
