Camp, your best friend is READING ! See what everybody else built and just take the best parts of their construction that suit your needs …
I used 3.5” beaded foam , because I found large blocks really CHEAP , and could cut large 3.5” thick planks from them … It’s Very Strong and has lasted many years longer than any other trailer I’ve had or made …
Ps. You want to do your best to restore your trailer as that’s what everything else sits on …
![Wink ;)](./images/smilies/econ_wink.gif)
For extra strength , you can weld or bolt on new metal to strengthen it …
1” X 4” maybe too much for window framing … Mine has no window framing at all … windows glued to Foam … The only place I used 2X4s was on the trailer as spacers between trailer and foam ( eliminating the need to construct wheel wells … )
We find making drawings and constructing a small model really helps plan things out …
![73427](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=73427)
