when you built your trailer
The body to my tear was built with ....
a frame like a house
5
31%
cut out the plywood sides, attached ribs in the middle
10
63%
other explained below ...
1
6%
Total votes : 16
Postby Ron Dickey » Thu Nov 11, 2004 11:33 pm
When you built your trailer did you or will you.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby Woody » Fri Nov 12, 2004 12:03 am
1/2" plywood walls, 1 1/2" furring strips mounted to plywood, 1 1/2" foam insulation installed between furring strips. 1/4" panel interior wall installed is the way I built my body.Skinned the top of the roof with 1/2" plywood for roof rack and solar panel install. Skinned front curve with 1/4" and rear hatch. Floor 1/2" plywood boottom with 2 x 4's in between with 1/2" floor with 1 1/2" insulation in space between plywood layers. Pretty much sums it up
Woody
E-mail: tearjerkerfla@bellsouth.net
Woody
Images: 26
Postby asianflava » Fri Nov 12, 2004 2:06 am
I cast my vote for "other" but I guess it falls under "frame like a house." I was thinking "other" because it is glued up which is unlike a house.
asianflava
Return to User Polls
