head or feet towards hitch for sleeping
Postby Sodapop Teardrop » Mon Jul 09, 2007 4:52 pm
Feet toward the hitch / head toward the "kitch" :lol: I crack myself up sometimes...other times I'm just cracked... :?
"We do not stop playing because we grow old;
We grow old because we stop playing."
Sodapop Teardrop
Postby Gerdo » Mon Jul 09, 2007 5:07 pm
Our feet are toward the hitch. The inside of my TD is big and open with only cabinets at our feet.
I built big enough to keep from having cabinets over our feet. Claustraphobic!
Gerdo
Images: 156
Postby pauld3 » Mon Jul 09, 2007 5:16 pm
As long as you both have your feet facing the same directions, and you are not hitting your head on anything...I think you're ok!!!
My grandmother and I used to lay with our head at the end of the bed because it seemed cooler, but then again there was a window at the end of her bed...I guess that's different! :oops:
Our tear drop has our feet toward the tongue and under cabinets.
Lynn
Paul & Lynn Donovan
The Toad Drop Inn
Liberal, KS
pauld3
Images: 94
Postby ob1canola » Tue Aug 21, 2007 10:37 pm
head toward the hitch.
ob1canola
Postby deserthawk » Sun Sep 16, 2007 2:56 pm
I sleep both ways depending on what tear I'm in. I have a six wide "comunications shack" made from a lil'guy sport with a large satellite dish mounted on the front. Don't know if it was originally built like this but it has cabinets to the front. If sleeping with my feet towards the galley it seems like I would bang my head every time I sat up. At first it seemed a little a**-backwards but I'm kind of getting used to it now.
NEW - ITG Photos 2009
http://www.emuranch.com/ft/itg/galleryitg.cfm
IRG Photos 2008 http://www.emuranch.com/ft/irg/galleryirg.cfm
"It's not where you are that counts....It's where you're at." Full Time Teardroper 810 Continuous Days living out of my TD as of 8/15/2010
deserthawk
Images: 106
Postby Ron Dickey » Thu Sep 20, 2007 11:18 am
mine is removable so it could go "I"ther way.
Ron Dickey :lol:
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby benzu » Thu Sep 20, 2007 2:31 pm
On mine it will depend we are putting our furnace out the front through the storage box. So on the cold days we will turn our heads to the galley and on the warm days we will have our heads near the hitch. That could change though after testing out the furnace output.
Mike
benzu
Images: 119
Postby b.bodemer » Fri Oct 05, 2007 9:52 am
Barb
b.bodemer
Images: 290
Postby Bill Fernandez » Fri Nov 09, 2007 6:36 pm
bledsoe3 wrote:Most tears have the doors towards the front of the trailer. It's just easier to sit in the door, kick off your shoes, lean back and swing your feet to the rear of the tear.
I'll but that
Wild Bill The Shoe Man
If The Shoe Fits, Fix it!
<img src="http://tearjerkers.net/forums/album_pic.php?pic_id=46" border="0" />
Bill Fernandez
Images: 119
Postby Gary and Cheri » Mon May 05, 2008 10:07 pm
I can understand sleeping either way if you have the same head space.
If you have already put the doors in then for me you have already made the decision on which way I would prefer to sleep.
I never set up my tear totally flat. I always give a little gravity help to keeping the door naturally toward the closed position vs a door that may try to open naturally. Since most doors are hinged on the hitch side, as mine is, I sleep with my head towards the hitch. I dislike sleeping with my feet higher than my head.
Obviously a personal preference.
Gary
Gary and Cheri
Postby Gerdo » Tue May 06, 2008 12:48 am
Gary
I on the other hand like the door to swing toward the open position when setup.
I agree with feet lower than my head. That is one problem that I have is that when hitched up and on level ground the hitch end is slightly higher making my feet high. I have to either nose down hill, roll up on some ramps or unhitch and lower the tongue.
Gerdo
Images: 156
Postby Jst83 » Tue May 06, 2008 8:29 pm
Miriam C. wrote:
Jst83 wrote:Side to Side.
:oops: oops that wasn't one of the choices.
But that's the way I sleep.
:thumbsup: Yep---side to side. Just gotta decide which side. :lol:
Which ever side is up hill other wise you wake up with a super headache :lol:
Jst83
Images: 215
Postby traveler » Mon Jun 09, 2008 7:12 pm
head
Why do anything unless it is fun with your teardrop
traveler
Return to User Polls
